B2650 Front Mount Snowblower Attachment
   / B2650 Front Mount Snowblower Attachment #1
abcuster
PA
Kubota
I'n in the process of buying a B2650 with the front mount 63" snowblower, backhoe and loader attachments. Since I cannot find any manuals to verify, I have a few questions re: installation of subframes for all attachments (preferably simultaneously):
1. Can the backhoe subframe and snowblower subframes be installed concurrently?
2. Can the snowblower subframe be left in place while installing/operating the loader? Or similarly, can the loader arms be left on/locked in place when installing/using the blower? How hard is it to attach/remove the snow blower to switch to the loader?
3. Is it necessary/recommended to remove the snowblower subframe during forestry work to prevent damage? How long does it take to install/remove the snow blower subframe?
Can't find any videos on YouTube showing these processes. Thanks!
   / B2650 Front Mount Snowblower Attachment #2
Here are my answer: 1 Yes 2. NO. The snow blower sub frame can be dropped in a minute. One bolt and a pin. The FEL can be installed in a couple of minutes. The snow blower can be attached/uninstalled in a minute. 3. Because you can't leave the sub frame for the blower on and use the fel I wouldn't leave it on. It would decrease your ground clearance and probably get screwed up.
I tried leaving my back hoe on while snow blowing and rapidly found that the front end was very light when blowing with the blower in the float position.
As an aside, I switch between my blower, plow and FEL during snow season and other than hooking up hydro lines in the freezing weather I have no problems ( I keep a heat gun handy to thaw fittings). I keep all of my attachments on moving dollies so I can drop one piece of equipment and move another into position very quickly without having to jockey the tractor around. I'm 72 so I don't manhandle any attachments if I don't have to.
   / B2650 Front Mount Snowblower Attachment #3
As Sandyc said and I concur....The front mount snow blower attachment frame attaches/detaches in a couple of minutes, no reason to leave it attached and besides it uses the FEL hydraulic lines so you'd have to chain it in the up position if you attempted to hook up the FEL. The blower mounting frame hangs down quite low to the ground so leaving it attached while out in the forest is not a good idea....and as stated earlier, it is so easy to attach/detach that leaving it there when un-needed is pointless.
Thanks for the replies - appreciate your input!
WHITE CI-7 DRAW WORKS POWERED BY TWIN (60 SERIES) DETROIT 14.0L ENGINES (A50854)
WHITE CI-7 DRAW...
2018 John Deere 645FD Flex Draper Head (A50657)
2018 John Deere...
2012 Toro Greensmaster 1600 Walk Behind Mower (A48082)
2012 Toro...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51219)
2015 FREIGHTLINER...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
Komatsu PC490LC-11 Hydraulic Excavator (A49346)
Komatsu PC490LC-11...
