I've been having a problem more and more often with by B2620 shutting down once I leave the seat. I know, you are all thinking I left the PTO engaged, but that is not the case. My dealer gave me a long lecture on this before I even received the tractor, telling me NOT to call him if the tractor won't start until I checked that the PTO was engage. However, this problem didn't start happening until after I started using the PTO for the first time. Before then I did about 10 hours worth of landscape rake and loader work with no problem.
Whenever this happens (the tractor shutting down when I leave the seat), when I first try to start the tractor up, nothing happens except for the normal dashboard lights. The first couple times it happened, pressing on the clutch allowed me to start it up. However, now it is happening about half the time I leave the seat, and I can't get it to start until I basically depress every pedal and move every lever a couple of times.
I recently spent about 10 minutes doing this repeatedly: engaging and disengaging the PTO, depressing and releasing the clutch, depressing and holding the clutch, pressing the forward and reverve pedals, lowering the loader and 3PH. I was all set to give up, when I decided on one last turn of the key and it started.
I'm guessing this is related to the PTO in some way. Probably whatever is suppose to detect that the PTO is engaged is getting confused. BTW, there was at least one time when I got off the seat with the tractor running (and it didn't shut down), got back on, did some loader work, and when I got off again it shut down. I never touched the PTO in this case. I think all the other times I had used the PTO.
Any suggestion? Should I just let the dealer handle it, or is there something I can try on my end first?
