B2620 Rear HYD remote options?
   / B2620 Rear HYD remote options? #1
Jbbies
Bronze Member
Colorado
Kubota B2620
I asked this question awhile back and didn't get an answer so I will try again.
Has anyone installed the optional Hyd. Rear Remotes on the B2620 or similar tractor?
If so can I see pictures of the set up? I would like to purchase the kit but the dealer cant really tell me much about it.
Also anyone done a DIY version for this tractor.
Thanks B
   / B2620 Rear HYD remote options? #2
I got lots of help when I did my B2710, here's the thread. If you search you'll find lots of threads on this topic, several people bought the kit, some went the DIY route like I did because it's lots cheaper. There's also been some threads on what fittings to use, where to buy them online, and where to get the hoses made up.
   / B2620 Rear HYD remote options? #3
I have done it both ways. Unless you can get a valve real cheap I would go with the kit. I did the diy way on my b7800, but I got the valve (2 spool) for $40.00 and the hose and fitting were around $100.00. My valve was off a JD lawn more, small and 10gpm. Worked out great.
   / B2620 Rear HYD remote options? #4
Maybe this well also help.
  • Hyd. Remote Valve For Kubota B2630 & B3030.pdf
Well The Kubota Kit for my tractor is $700 plus. Ouch. Only reason I would be interested in it is for the lever and if it would look factory not sure its worth that much though.
Lee John it looks like with the kit you got from Kubota it locates the levers in the area on the fender? Did they include the panel with the kit?
   / B2620 Rear HYD remote options? #7
The kit I put on was for a L3130 that I had. The dealer helped me out on the price and if you got it new from the dealer you got the price from I would think he would give you a brake. I would think it would come with the 1st valve kit and not the 2nd.
2008 International 4400 Terex Hi-Ranger HRX-55 55ft Material Handling Insulated Bucket Truck (A48081)
2008 International...
2012 Hyundai Veloster Hatchback (A46684)
2012 Hyundai...
10-16.5 SKS6 Tires (set 4) (A49251)
10-16.5 SKS6 Tires...
2012 Chevrolet Malibu Sedan (A46684)
2012 Chevrolet...
2022 John Deere XUV825MS4 4x4 Gator (A49251)
2022 John Deere...
2012 Fiat 500 Hatchback (A46684)
2012 Fiat 500...
