B2620 and loader
   / B2620 and loader #1
aggc
Milmine, IL
I've been hearing a lot of good things of the new B2620. As far as the loader goes, what's a maximum weight you can lift and carry safely with this tractor? Is 600 pound too much? The rear tires would be loaded and with adequate ballast on the 3 point hitch.
   / B2620 and loader #2
952lbs (pivot pin), 661lbs (19.7 in. forward). This is from the specs on the kubota site.
   / B2620 and loader #3
Hi I have a B2620. The loader is quite strong. I have loaded r4's and usually have my 275 lb landscape rake attached to the 3pt. I have been recently (still a work in progress) been building retaining walls/landscape borders out of boulders/rocks I have on the property. I have easily had 600 lbs. in the bucket while doing this work and have had no problem moving the tractor around. Deffinitly load the tires as you suggested and have proper ballast on the back. Between both tires (280) and the rake 275 I have 555 lbs. of ballast and have had no issues at all. If I did need more ballast I could add my BB and get 475 lbs from that alone, but have not needed to yet. Love the tractor!!!!
New/Unused 20ft Farm Iron Gate (A48837)
New/Unused 20ft...
2014 New Holland C238 Tracked Skid Steer (A50860)
2014 New Holland...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2015 MACK GU713 (INOPERABLE) (A50854)
2015 MACK GU713...
Box blade (A50860)
Box blade (A50860)
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
