B2620/2920 loader mounted plow
   / B2620/2920 loader mounted plow #1
bxowner
Vermont
John Deere 5055e
I'm continuing with the research on these models... and wonder if anyone has mounted a Fisher or Curtis front blade to replace the bucket on a B2620 or B2920? I know it can be done with the B7800 and B3200, as well as the B2630 and B3030 models. I'm also aware that the quick-attach from a B3200 can be added to the loader frame onto the B2620/2920. What I'm wondering is whether anyone has actually done this? I am aware that there is concern with bending or torquing the loader arms, but it's for personal use, not a commercial application.
I just wonder if the loader on this series tractor is up to the task or if I should be holding out to buy the larger B3200 size. I only have 3 acres and a lot of obstacles, so the smaller frame B-series is more attractive to me.
   / B2620/2920 loader mounted plow #2
One of our members I beleive ChuckinNH has the quick attach for the loader, I know he uses for Forks but not sure if he has the front blade or not but at least he can chime in on the front Quick attach. I beleive he has the B2620, he did have a few threads/posts w/ pics of the set up in the Kubota threads do a search and you will see it. Good Luck
2015 FREIGHTLINER CASCADIA DAY CAB (A51219)
2015 FREIGHTLINER...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump with Hose Reel (A49461)
2025 LandHonor...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
White 2-55 Loader Tractor (A50514)
White 2-55 Loader...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A49461)
2007 Bomag...
2017 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2017 CATERPILLAR...
