RalphVa
Super Member
- Joined
- Dec 19, 2003
- Messages
- 7,885
- Location
- Charlottesville, VA, USA
- Tractor
- JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
Well, I thought I'd submitted a review of the B2601 in the Reviews area, but I made a mistake on the hours. Went to correct it, and it was not there.
So, I'll sumit it here and let the guy(s) who check this site move it to Reviews.
I bought the B2601 in January, driving 2 hours up to Winchester Equipment Co. because NONE of the dealers closer had no loaders. Even WEC had no B2301s. Bought for my 80th birthday in April but did it early because I'd heard of shortages on this site.
It now has 74 hours on it.
I've compiled ways B2601 is better than JD 2 series, as I've owned two 2 series ones and a lemony 1025R.
o Starts cold a lot better: no shudder/shake nor smoke..
o Float on FEL is very easily engaged, almost too easy.
o 2wd/4wd is so easy.
o Hydraulics are MUCH stronger. Flow is near 3 times but makes for a more jerky FEL use.
o Idles nicely at 1,100. The 1025R was abnoxious at 1,650; 2025R was 1,300.
o Drink holder is bigger than the joke one on the 2025R. Not sure it'll hold my little thermos. Put the Frontier doc holder top on the left side of the FEL tower as my drink holder.
o Parking brake is easier to disengage but seems a tad harder to engage.
o Guards to the valve stems.
o Metal covering over the driveshaft (JDs only have plastic)
o 3ph raises a tad higher
o The fuel cap actually screws on and off easier.
o The radiator overflow container is right in front and easy to get to. Needed a screwdriver to take the top off the one on the 2025R and a funnel with long snout to refill it. Then top was hard to put back on. Actually, the B’s is not much easier to get off, and a long snout funnel is needed on it.
o More room to get the end snorkel off the air cleaner.
o The brake pedal lock snaps off by tapping the pedals. Hard to get off at times on the JDs.
o Top link is really easy to turn, e.g. that grease point maybe. Actually smaller, too. The tilt one is also smaller and easy to turn if load is taken off it..
o Three position steering wheel.
o Of course, 3 range HST control. Only 2 on the JDs.
o Fuel use is 0.016 gph/engine hp vs. 0.025 gph/engine hp on 3 Yanmar JDs. Exhaust is not blackening the back side of the FEL.
o Slightly lower hood for easier refill. Have a battery pump that makes this easy by sitting container on foot area of the tractor.
o The stuff under the seat is easier to clean out. There’s a clear path to put silicone spray on all moving parts. All the JDs seemed to have a pan/sheet metal there that made cleanout almost impossible.
o Quiet HST vs. 3 JDs that whined like mad.
o No stinking driveshaft Ujoints to grease.
o STILL has steering brakes.
