B26 Hydraulic Fluid coming out of breather tube
   / B26 Hydraulic Fluid coming out of breather tube #1
AlaskaJohn
I have a 2013 B26 with 700 hours on it. It is 35 degrees outside so I started it and let it warm up for 15-20 mins. When I went back out to get on it, there was about 2 quart (I'd guess) of hydraulic fluid on the ground under the 3 pt. hitch area (I have the backhoe on it). The oil came from the breather tube next to the fill area for the hydraulic/transmission fluid.
I've checked the fluid level and it is low...of course. Also, the hydraulic fluid on the ground had a white milky look to some of it (water?).
Thanks for any help!
John
   / B26 Hydraulic Fluid coming out of breather tube #2
Just a guess, sounds like there was some water in a line that froze and caused an overflow. Are the connections for the bh attached properly?
UNUSED FUTURE FR70 69" LEVELER (A51248)
UNUSED FUTURE FR70...
2023 John Deere S780 Combine (A53342)
2023 John Deere...
2018 JOHN DEERE 5075GN LOT IDENTIFIER 91 (A53084)
2018 JOHN DEERE...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A53472)
UNVERFERTH 330 8...
2005 Caterpillar 430D 4x4 Extendahoe Backhoe Loader (A51691)
2005 Caterpillar...
