B2410 Rear Tire Settings (again)
   / B2410 Rear Tire Settings (again) #1
RhallVA
VA
Hi all,
Thanks for you responses on this over the last week or so. I have two more questions if anyone has time.
The consensus in the other thread seems to be that the rear wheels (unless you have a special situation like narrow orchard rows, storage space and so on….) should be set as wide as possible for safety reasons. No one has mentioned any reason not to have them set wide, even with a MMM. As one pointed out the Kubota MMM manual specifies that the wheels be set to their widest position. All this makes sense…but…
I was looking at mine yesterday and it appears that if I move the rear wheels outward they will extend wider than the width of the MMM.
1-Will this make for a less attractive cut as the rear wheels (filled) pack down the grass that will not be mowed until the next cutting pass?
2- Do all of you go back and trim with a smaller mower to get closer to fences, buildings, etc…? The rear wheels being wider than the cut will make me cut a good bit further from the borders.
Thanks again for any input!
Roy in VA
   / B2410 Rear Tire Settings (again) #2
rhallva,
i have the rear tires on my 2410 all the way out and have not once had a problem. as i recall the mmm is still just a tad wider on the left side, and the chute on the right extends about a foot past the tires. the only issue you might run into is that the right rear scalp whell will spin on the rear tire if you have turfs. this has not caused a problem for me but you just notice it all the time when you are driving.
Flail Mower (A49251)
LOAD OUT AND SHIPPING (A48837)
LOAD OUT AND...
16FT BUMPER PULL SPOOL TRAILER (A48992)
16FT BUMPER PULL...
2021 Ford Explorer SUV (A48082)
2021 Ford Explorer...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
Kubota B2100 4WD Compact Tractor (A49251)
Kubota B2100 4WD...
