B2410 Purchased
   / B2410 Purchased #1
Rodney
Bronze Member
Southern Indiana
NH 1920 TLB
Couldn't find my old post, but last summer we discussed which small frame tractor (NH JD or Kubota) was the best for various applications. I finally decided on a B2410. Found a 2002 model with 23 hours on ebay that did not sell. I called and eventually bought it, it has proven to be a nice unit. It now has 35 hours registered. It had a mmm and a powerful grass/leaf bagging system. I may sell the bagger on ebay this spring. Also, purchased a 4' brushog from Rural King, my 5' was a little large for the Kubota, would hardly lift it high enough especially in ditches. Bottom line is this is a nice tractor. Went with the B2410 over the B7800 because of the position control. Bypassed JD and NH because of a perceived lower center of gravity. I'm definitely not color blind, I have a JD mower NH and Kubota CUTs.
   / B2410 Purchased #2
Congratulations! There a well built tractor.
   / B2410 Purchased #3
have had my b2400 for 3 years now and have found it to be relaible and all i expected it to be. think u will be pleased with it.
   / B2410 Purchased #4
Love my Kubota 2410 even though it is not TBN PC to like Kubotas. /forums/images/graemlins/smirk.gif. You will like your 2410 too. Did you get an FEL or are you going to use your NH for that work? J
   / B2410 Purchased
Trescrows, I plan to use my NH loader but would buy a loader for the 2410 if the right deal came along. Local dealer said he may be able to locate a good used loader for $1200 to $1400, I told him I would take it. I doubt they come up with one though. Mine has a brush guard, will the loader interfere with the guard? I am also interested in suitcase weights as the front end is quite light with a brushog on. Anyone have some for sale or recommend an aftermarket source? Dealer had some ($42 for 45lb) but would have to be modified. I may buy 3 of the kubota weights (55lbs each for $65 including shipping). Do I need 3 or 5 weights, with a special bracket I can get 5 kubota weights to fit on?
   / B2410 Purchased #6
Not sure what guard you have but the FEL mount incorporates a brush guard. I have seen home made weights up front but I do know Kubota sells a braket and weights. It would not be terribbly diffucult to make your own. J
   / B2410 Purchased #7
</font><font color="blue" class="small">( Love my Kubota 2410 even though it is not TBN PC to like Kubotas. /forums/images/graemlins/smirk.gif. )</font>
Since when ?
2003 Ford F-250 Pickup Truck, VIN # 1FTNX20L23EA74972 (A48836)
2003 Ford F-250...
2004 Ford F-750 Crew Cab Wrecker Tow Truck (A48081)
2004 Ford F-750...
Cram-A-Lot Vertical Hydraulic Balers (A49346)
Cram-A-Lot...
2017 Ford F-250 Ext. Cab Reading Service Truck (A48081)
2017 Ford F-250...
Clark CDP 164 Forklift (A48837)
Clark CDP 164...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
