B2410 - How do I "pin" the mower deck
   / B2410 - How do I "pin" the mower deck #1
jfdlaw
Webster, NY
Kubota 2410
I can't find my manual for my mower deck. Figuring someone here can give me the answer.
How do I pin the mower deck in the up position so that I can use a rake on the three point hitch without removing the mower deck?
   / B2410 - How do I "pin" the mower deck #2
Hello I have a bx 25 that has a dial setting for the mower deck just adjust it to the highest setting aand you can still use the 3pnt hitch
No dial like that on the B2410/B7500 models. height is adjusted by height of guide wheels. Thanks though.
   / B2410 - How do I "pin" the mower deck #4
Look at the back of the deck. There is a place on the back where you can put a 3/8" pin through deck and tractor brackets (or there is on our B7500).
We have to lift the deck all the way up with the 3 point, then lift it a little by hand to let the pin fit in.
Aaron Z
There is a place near the front (6-8" back from the front) of the deck that will match up and has a place for a decent size pin. Seems like a lot of torque to have the pin on the front half of the deck, but I guess that's what it must be. Thanks.
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
210000 (A60429)
210000 (A60429)
KBH 25T Tender (A56438)
KBH 25T Tender...
Zero Turn Mower (A59228)
Zero Turn Mower...
2016 FORD F-550 UTILITY / MECHANICS TRUCK (A59575)
2016 FORD F-550...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
