B2410 Grinding noise
   / B2410 Grinding noise #1
Benja
Hello,
I've got about 150 hours on the tractor and it was bought about 5 years ago, new.
The grinding noise is intermitting and usualy appears after releasing the emergency brake.
It seems to come from the right rear wheel and has a grinding, crunching sound that sometimes goes away after various forward and reverse operations.
Anyone else experience this?
Thanks,
Ben
   / B2410 Grinding noise #2
I have a 2 year old B7610 (which is very similar to the B2410) with about 150 hours on it also. I have never experienced those type of sounds.
What were you doing with the tractor just prior to the sounds developing?
   / B2410 Grinding noise #3
I'm not sure about the B2410 but a somewhat common problem w/B7500/B7510/B7610 is the nuts/bolts that lock the wheel on the axle can work loose and cause all kinds of strange intermittent sounds. These are the nuts/bolts that you loosen to adj to be able to move the rear wheels in or out on the axle.
Usually a very easy fix (re-tighten the nuts/bolts)
Good luck
   / B2410 Grinding noise #4
I would definately check the axle bolts.
2012 TAKEUCHI TL12 SKID STEER (A60429)
2012 TAKEUCHI TL12...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
2009 Peterbilt 384 Semi (A59814)
2009 Peterbilt 384...
Tractor (A59228)
Tractor (A59228)
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
