B2400HST Hydraulic Problems
   / B2400HST Hydraulic Problems #1
PDAJay
Pelzer, SC
Kubota B2400
I posted this in the Hydraulics section as well, but figured I would try here also...
Okay, backstory on problem.....
Pressure line going to power steering pump developed a crack, since the previous owner had brazed it (badly) before, I had to have my local hydraulics place make a replacement for me.
Get home, get everything installed and fire the tractor up. Discovered quite quickly that I had not tightened the hydraulic pump fitting (oops). Shut down engine, tightened fitting and cranked back up.
Go through bleeding procedure, seems very stiff. Try front loader, nothing.
Check flow control and it is fully open. Fluid level is good.
Lower 3ph and then try to raise it back up, no go.
Tractor will move forward and backwards without issue (other than dragging front loader bucket on concrete).
Any ideas on what I should try next?
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2008 Doosan Mega250-V Articulated Wheel Loader (A52377)
2008 Doosan...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2010 Hyundai Elantra Touring Sedan (A54815)
2010 Hyundai...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
