B2400 Models
   / B2400 Models #1
Gro_Kiwi
California
There are three models of the B2410, the B2410HSE, the B2410HSD and the B2410HSDB.
What does the HSE, HSD and HSDB stand for?
   / B2400 Models #2
The HSE is two wheel drive hydro, the HSD is 4WD hydro and the HSDB is 4WD with bi-speed option. The bi-speed turning feature spins the front wheels faster to allow easier turning while the FEL is loaded. It is nice but not really that big a deal. Like I said, it does reduce steering effort which is nearly effortless anyway and slightly decreases turning radius when the FEL is heavily loaded. Good luck. J
   / B2400 Models #3
Trescrows' answer is correct. The only thing I would clarify is that the bi-speed will always turn the front wheels quicker for tighter turning, not just in conjunction with the FEL. I have the bi-speed on my B2410 and only use it in tight areas. You can turn it off when you are not using it. The only other time I use it is when I am cutting tight corners on loose soil or turf because it tends to lessen the damage to the ground. Good luck with your search for a tractor, the B2410 is a great model.
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
2000 Freightliner FL70 Manitex 14 Ton Crane Truck (A55788)
2000 Freightliner...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A55852)
2007 Ford E-450...
2021 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
