B2400 MMM and Backhoe
   / B2400 MMM and Backhoe #1
Gomez
Bucks County, PA
Kubota B2400
I was hoping to be able to keep the MMM attached if I needed to install the backhoe (Woods BH65) for a small job.
One problem I'm having is the deck can not lift to the height required to insert the holdup pin.
The left side of the deck is fine, but the right side interferes with the bottom of the sub-frame (mower discharge tunnel).
I tried moving up the sub-frame bracket but still need another 1/4" or so.
The current access to install the holdup pins is less than easy with the FEL and BH sub-frames.
I was thinking of welding a piece of angle to the deck that would allow it to be pinned up to the bottom of the sub-frame where it clamps onto the FEL bracket.
I'm open to any other suggestions.
Thanks!
Informational Lot - Shipping (A53473)
Informational Lot...
2018 Ford F-150 Ext. Cab Pickup Truck (A51692)
2018 Ford F-150...
2012 Bomag BC572 Refuse Compactor (A51691)
2012 Bomag BC572...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
2011 Homesteader Box Trailer, 6'x10' (A52384)
2011 Homesteader...
