Todds112
Finally got to the 50 hours mark. Took just over a year! Our winter was below average for snow fall, so I hardly ran her at all.
Anyway, got my filters and oil, everything I thought I needed for the service.
I'm using Amsoil 15W40 Synthetic in the engine.
Oil change was more of a pain than I anticipated. Who designed the location on the oil filter?! Right up against a radiator hose and in a location that lets lots of nasty used oil leak down into the frame and frame cross member. Made a mess there. I bet oil will drip for the next month from the nether regions no rag will get to.
I also shredded my fingers on the radiator drain valve and the clips that hold the hoses on. I bet the same guy designed the oil fill to be right under the center support rod and that cable. Even using a funnel I managed to spill oil down into the motor.
Moved to the back of the tractor to do the transmission oil filter. Looked at the manual and the filter and figured out the dealer gave me the wrong filter. I got a hydraulic oil filter. Wait, I thought the hydraulic oil was the transmission oil and vice-versa.:confused3:
Well back to the dealer next week to get the correct filter. I am assuming all the hydraulic fluid will run out of the tractor when I try to change the filter (that's just my luck). I was thinking I wanted to change to SUDT2 anyway, so I might just replace the fluid and both filters. With my average usage so far it would almost 8 years before the service actually calls for it!
I also need to pick up a new hydraulic line for the loader. The cloth sleave thing wasn't up far enough and the loader frame ate right through the one rubber hose. Can't believe it hasn't burst. It's worn a third of the way into the hose. But the cloth sleave does do a great job of sanding the paint right off the side engine cover panel. All in just 50 hours.:mur:
I thought being a bit bigger the B would be easier to service than my BX was, but I didn't have nearly the aggravation with it.
Just having one of "those" days I guess.
