B2150 hydraulic loader control
   / B2150 hydraulic loader control #1
wwohnus
would like information on repair vs. replacement of the control for the front end loader. mine has worn seal(s) on the bucket roll and has no scooping power. the dealer has told me the only solution is to replace the entire unit. is this so?
   / B2150 hydraulic loader control #2
This may in fact be true. The bore and piston in the control are precision ground, there are no seals internally to replace… if yours is scared or worn to the point that it is leaking, replacing is going to be your only avenue. … You might check the tractor salvages and find a set that will replace yours. Good luck, and welcome to TBN. KennyV.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
KENWORTH  DIGGER TRUCK (A50854)
KENWORTH DIGGER...
INGERSOLL RAND COMPRESSOR (A50854)
INGERSOLL RAND...
2018 John Deere 35G Mini Excavator (A49461)
2018 John Deere...
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A51039)
2018 Rock Solid...
New Holland B95 Backhoe (A50490)
New Holland B95...
