B21 starts, stalls. Below freezing, Gelled fuel line?
   / B21 starts, stalls. Below freezing, Gelled fuel line? #1
joea99
Platinum Member
Marbletown NY
Kubota B21, JD 240GT
Pre-heated, glowed. Started, idled low, quit. Now starts and quits.
Unscrewed and removed fuel filter and fuel only drips out. There is fuel in the tank. I did have water last summer (don't ask) but drained it and ran it for several small jobs after that.
What's a good fuel treatment for this? Do I dare try to heat the hoses?
So a heat gun applied to the inlet started fuel flowing, now warming up. Still, what fuel treatment will fix this?
   / B21 starts, stalls. Below freezing, Gelled fuel line? #3
Power service in the white bottle. About 1-2 oz/5 gallons will work.
   / B21 starts, stalls. Below freezing, Gelled fuel line? #4
There is also a "911" product in a red bottle
   / B21 starts, stalls. Below freezing, Gelled fuel line? #5
What is the temperature?
   / B21 starts, stalls. Below freezing, Gelled fuel line? #6
911 red bottle is for fixing screw ups & frozen fuel. White bottle is for preventing it. If it's a water problem there are some sticks & stuff that will absorb water but not fuel, or you dump/drain the tank.
   / B21 starts, stalls. Below freezing, Gelled fuel line? #7
There is a product from Clean Flo (without w). It's a blue-ish bottle. This product removes moisture.
Since water settles to the bottom of the tank and you have some flow now, just drain a quarter of fuel and it should take the water with it. It doesn't take much to plug the line.
2012 Ram 1500 4x4 Crew Cab Pickup Truck (A49461)
2012 Ram 1500 4x4...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A49461)
2009 Trail King...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52128)
2022 Down2Earth...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
2019 Komatsu PC490LC Hydraulic Excavator (A49461)
2019 Komatsu...
