B21 problem
   / B21 problem #1
MarkV
Super Member
Cedartown, Ga and N. Ga mountains
1998 Kubota B21, 2005 Kubota L39
I had a problem this weekend that I had not experienced before and thought some of you might be able to shed some light on what happened. After about 5 hours of continues use of the backhoe and loader on my B21 the hydraulics gave out. The backhoe would not respond at all and the loader would rise in about 6” increments and then stop. The tractor temp gauge read normal, hydraulic fluid showed full (best I could tell on that silly yellow dip stick), could not find any leaking, the fluid did not feel abnormally hot and the fluid looked normal. (Changed less than 50 hrs ago and no foaming visible) After about 20 minutes of looking and checking the tractor ran fine for another 2 hrs of work.
Any ideas? Would air in the system do something like this and if so, how would it get there?
MarkV
   / B21 problem #2
Mark,
Sorry you're having a problem. I don't have any answers/w3tcompact/icons/frown.gif but I do have a question. When this problem occured was operation of the HST and steering normal or was it affected also?
Al
   / B21 problem
Al,
Good question and I should have added that in my first post. The steering was fine and the HST was working the best I could tell. I had lowered the backhoe and could not raise it so my test was limited.
If I have a problem I am not sure what it is. After looking things over, checking fluids and reconnecting the lines to the backhoe things worked fine the rest of the day. It was strange and I thought someone might point out something I am missing.
Thanks for your interest.
MarkV
   / B21 problem #4
Mark,
I plan a trip to my dealer tomorrow to pick up some mower blades. I will
drop out in the shop and see if the mechanic may have some ideas. One of his is worth more than ten of mine.
Al
   / B21 problem #5
Mark,
I pulled out the hydraulic schematics and the only single failure I see that is common to the loader and hoe and not HST and steering is the relief valve. If this is the problem it's no big deal, easy to remove and no big ticket items inside. Perhaps a spring, obstuction in the seat?? This is my best guess other than your idea. I will check with the mechanic tomorrow.
   / B21 problem #6
Let us know how you make out because I have the bigger brother and may someday also run into this....Hopefully not but that's whats great about this site because if you need something you can normally find it out here. /w3tcompact/icons/smile.gif Goodluck with your project.
Darin
   / B21 problem #7
One of the quick couplers came disconnected even though they looked connected. I've had this happen many times over the years.
Brian
   / B21 problem #8
Sounds like the drive to the pump may be slipping. We had an instance where the hydraulics worked intermittantly, and when turning the pump by hand ,everything looked OK.
It may be possible that the drive splines just slip on a worn section of the drive, and then make just enough contact to drive again.
The only other possibility I can think of is an interruption to the oil supply. Dirty strainer or similar problem.
   / B21 problem
Al,
Thanks for taking a look at your service schematics. If the problem continues I will be looking at the relief valve first.
MarkV
   / B21 problem
Brian,
Your thoughts and experience are always valued so thanks for jumping in. I had thought about the quick connects as we were looking for the problem. I did disconnect and reconnect them and one did feel a little strange. At the time I thought, these things are either hooked up or not and we had been running for a good while so that can’t be it. If you have seen connectors break their seal while still looking connected it may be that simple. I’ll take a closer look this weekend and make sure there isn’t any dirt in there.
MarkV
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
TOOL BOX (A50854)
TOOL BOX (A50854)
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
2015 FORD F-150 (A50854)
2015 FORD F-150...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A51039)
2023 New Holland...
71062 (A49346)
71062 (A49346)
