B21 Clutch Problem?
   / B21 Clutch Problem? #1
RobbieBones
New York
B21 1,100 hrs 2007. I'm the second owner purchased it with 600 or so hrs. Today while going up slight incline machine started screeching and grinding. Putting it in neutral the noise is not as bad, put the clutch down noise is much worse. Is there a way to diagnose that it's the clutch not the tranny? Forward and back pedal feels slightly funky but not sure if it's not because the clutch won't engage. Tractor will not move at all. Need help has its stuck on someone else's yard.
   / B21 Clutch Problem? #2
Sounds like a clutch issue since pressing the pedal makes the noise worse.
Either way, you need to tow it somewhere you can split it.
I did a clutch job and my 1989 wrangler. How bad is the B21 clutch job?
   / B21 Clutch Problem? #4
I guess you didn't need to split the Wrangler in half?
Other than that, pretty similar.
When you say split the tractor, you mean the tranny from the engine? Or split has in down the middle?
   / B21 Clutch Problem? #8
Trans/Engine. Front/Back halves to access the clutch.
On a tractor as small as a B21 a split should be relatively easy.
Probably should have a good repair manual, before beginning the project.
WACKER NUESON PUMP PT2A (A52472)
WACKER NUESON PUMP...
2015 CATERPILLAR 262D SKID STEER (A51246)
2015 CATERPILLAR...
2014 INTERNATIONAL MA025 (A52472)
2014 INTERNATIONAL...
9ft x 7ft Shipping Container with Side Door (A51573)
9ft x 7ft Shipping...
2009 UTILITY TRAILER MFG. CO. SEMI TRAILER 57 (A52472)
2009 UTILITY...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
