B2019 rear power beyond adapter
   / B2019 rear power beyond adapter #1
jeff77indy
Grantsburg, IN.
2007 4110 Mahindra w/ M112 loader and Kubota B2910 w/ loader.
B2910 rear power beyond adapter
Reading a few forums I have some owners have obtain an adapter to replace a cover plate in the hydraulic system so rear hydraulics could be installed on a B2910. Does anyone have the Kubota part number for this adapter?
Tractor is a 2004 model w/ LA402 loader.
   / B2019 rear power beyond adapter #3
Jeff77indy, Is your title correct? B2019 or should it be B2910?
   / B2019 rear power beyond adapter #4
My 2001 2910 had an LA 402 loader on it.
Joe
   / B2019 rear power beyond adapter #5
Is this what you're looking for? If not, you can search using Kubota's Illustrated Parts to find what you need.
Should have read B2910.
From what I have read on other forums is that there should be a plate at the rear of the tractor that routes the hydraulic fluid in the system to complete the power beyond circuit, the adapter in question replaces the original plate allowing for power beyond hydraulics at the rear of the tractor.
That is for the loader circuit, from what I have gleaned it would be a similar plate but is mounted to the hydraulics at the rear of the tractor.
   / B2019 rear power beyond adapter #8
Download the B2910HSD parts manual HERE and look at dashed box on upper left of pdf page 288 and index number 190 on pdf page 290. Is this what you are looking for?
That looks like it could be it.
Thanks.
   / B2019 rear power beyond adapter #10
I replaced that plate on my b2910 when I added rear remotes.
I think I posted a thread here with pictures, if I find it I will post a link.
Sorry I do not have a part number. Make sure you get the proper control valve(s) if adding remotes. You need to have flow pass through the valve assembly when the control levers are centered.
Bill
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2015 PETERBILT 567 TRI-AXLE (A52472)
2015 PETERBILT 567...
2008 ELGIN SWEEPER (A52472)
2008 ELGIN SWEEPER...
