B1750
   / B1750 #1
mccolby
Found a used B1750 HST w/FEL and mid-mount mower. Did this model come with power steering? It's listed as a 1990 with under 600 hours. Asking price is $10,000 which seems high to me. Any comment?
   / B1750 #2
My opinion is that $10,000 is a fair price for the 4wd version. I'm sure that if you did a lot of research you'll find them selling in the range of $9000-$11000.
Assuming the B1750 is designed like its big brother (the B2150), one of the problems that you'll possibly have with this tractor is that the mid-PTO and the rear-PTO operate from a single lever. This means that if you attach a 3-point PTO-driven implement while the mid-mower is attached then you will engage both implements simultaneously when you put the PTO in gear. To bypass this problem you'll have to either remove the mid-mower or at least remove the mid-mower's PTO shaft. Your particular usage will determine whether this is a problem or not.
A few minutes ago I put out another post with a lot of the B1750 specifications. I won't repeat them here.
Kelvin
   / B1750
Thanks Kelvin. Your other post was most helpful. The B1750 isn't too far from my home, so I'm going to check out the mid/rear pto situation, power steering and mower deck removal firsthand.
2019 Kia Soul (A53424)
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A54607)
2020 KENWORTH T680...
2002 Ferguson SP915RE Ride-On Pneumatic Asphalt Compactor (A52377)
2002 Ferguson...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
