chrisjbell
Platinum Member
- Joined
- Jul 17, 2000
- Messages
- 956
- Tractor
- Kubota B7300; JD LX233
Hi all,
It isn't my tractor, and I wasn't using it at the time, but a friend has a B1750 and I noticed that it was dripping oil. It started out as a pretty slow leak, but as the tractor was used longer it got pretty bad. After he got worried enough about it and shut it off we figured out the oil was coming out of the overflow.
Checked the oil level, and it is all the way up the dipstick.
This can't be right, I'm sure ;-).
He says this has happened once before and all he can remember doing to correct the problem was to change the oil a couple of times. I can't imagine a problem that would be solved that way, unless the oil filter is simply clogged (which would only take one oil change, I'd think).
Anyone have any ideas what would cause it? Better yet, any ideas on how to fix it?
Thanks...Chris
Thanks...Chris
