B1700 Rear Wheel Shear Pin broke after Hydraulic Leak
   / B1700 Rear Wheel Shear Pin broke after Hydraulic Leak #1
Quarterbranch
Lovettville, Va
2001 B1700
I have a Kubota B1700 and I'm not sure if the 2 things are related but...I had a metal tube that moves hydraulic fluid brake this week and I lost about 2 Gals of fluid before I realized I had a problem and shut my tractor down. I replaced the tube and everything seemed ok, sounded normal and I drove around the barn and field for about 5 minutes so I figured everything was ok. I then hooked up my rear PTO lawn mower go about 50 feet and realize there is something wrong with the rear wheel and thats when I notice the shear pin that hold the wheel on the axle is gone. I can sping the axle with my hand and it seems to be normal when in N and doesn't move when in gear and the other rear tire is on the ground. I don't know when the shear pin broke, it could have been like that before I had the hydraulic leak. Other then spinning them and listening for noise, how do I make sure the gears are ok? What would make the shear pin break? I'm at a bit of a lose to even know what to check, any advice would be appreciated.
   / B1700 Rear Wheel Shear Pin broke after Hydraulic Leak #2
They are not related. The pin is not a shear pin it's more of alinement pin. The bolt #130 must of been loose.
Thanks for the reply Leejohn, its actually part #160 that's missing.
Leejohn, after looking again I understand what you were trying to tell me and yes, bolt 130 is loose. Thanks for the help.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
UNUSED CFG INDUSTRIAL QK18R EXCAVATOR (A51247)
UNUSED CFG...
2011 CATERPILLAR 12M MOTORGRADER (A51246)
2011 CATERPILLAR...
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51247)
UNUSED FUTURE BOX...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
