B1700 Kubota rotary hoe spare parts
   / B1700 Kubota rotary hoe spare parts #1
mummyroo
humbug scrub south australia
b1700 kuboto
hi I need to locate a seller of spare parts in Australia .. we need the pin? that breaks before the rest does if it hits a rock.. even the name of what we need would be really helpful :)
   / B1700 Kubota rotary hoe spare parts #2
"sheer bolt" is what you are looking for.
i do not remember the recommendations. for what grade bolt to use. (grade = strength of bolt before it sheers) there is a "code pattern" that you can look up, and then look at the top of the bolt heads. to determine what grade the bolt is.
a local tractor dealer should have various grade bolts, and pending on local hardware store they will offer different size grade bolts.
get something that fits snug. (not needing hammer to drive bolt through) but still snug in the hole. have some extra sheer bolts on hand for when you do sheer them. a bolt that is to loose will "wobble the hole out.
if you can find bolts were you have head of the bolt then a straight piece (no threads), then threads on the end, the straight portion of the shaft might snug up better within given sheer bolt hole.
Unused 2025 GIYI KH72 72in 4-Way Hydraulic Bucket Skid Steer Attachment (A51691)
Unused 2025 GIYI...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
JOHN DEERE 16B GRAIN DRILL (A51247)
JOHN DEERE 16B...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
(INOP) KOMATSU PC200LC-8 EXCAVATOR (A51246)
(INOP) KOMATSU...
2001 Ford F150 (A50121)
2001 Ford F150...
