Chains [b]TIRE CHAINS FOR PT 422?[/b]
   / [b]TIRE CHAINS FOR PT 422?[/b] #1
BruceL
i'm a new to the forum and a relatively new pt 422 owner....and love it so far. recently i'm using it to clear snow from my driveway....it works great, but i would like more traction and thought a set of chains on the front may be the ticket.
has anyone had any experience using cable or other car chains with the pt? i'd appreciate any input and/or suggestions!
because the distance between the frame and the tires is minimal, i'm guessing the options are limited.
thanks,
bruce
   / [b]TIRE CHAINS FOR PT 422?[/b] #2
Re:
Hi Bruce. Welcome to TBN.
If you do a search in the Power Trac forums here on TBN you will find a thread on tire chains for the PT400 series as well as links to a place that sells them.
Try searching for chains and tire and you should get some hits.
   / [b]TIRE CHAINS FOR PT 422?[/b] #3
Re:
Hello Bruce,
Welcome to TBN and the PT family.
MossRoad mentioned this topic coming up earlier. I also was thinking of chains but then after one winter and current one, plowing snow has been no problem without them. There will be a few storms that would be nice to have chains but then I think the large bucket will be the order of the day.
What state are you in?
PJ
   / [b]TIRE CHAINS FOR PT 422?[/b] #4
Re:
I tryed chains on the front last Winter and didn't see much improvment in traction. I think you reduce weight on front wheels when pushing snow. I didn't try it but I bet chains would work better on rear.
   / [b]TIRE CHAINS FOR PT 422?[/b] #5
Re:
i use chains on the front ,work great ! angle the blade,up hill down hill, no crabing /forums/images/graemlins/cool.gifi cut 6" of ice off the drive way with the long corner of the blade.it woud get right under it and pop it loose /forums/images/graemlins/shocked.giffor chains look on tire chains.com get cross links every 2 links, they work a lot better. you can use float even on the gravel if it's hard /forums/images/graemlins/smirk.gif have fun /forums/images/graemlins/cool.gif
Re:
Thanks for the great input.....i'll follow up with some searches!
bruce
Re:
</font><font color="blue" class="small">( i use chains on the front ,work great ! angle the blade,up hill down hill, no crabing /forums/images/graemlins/cool.gifi cut 6" of ice off the drive way with the long corner of the blade.it woud get right under it and pop it loose /forums/images/graemlins/shocked.giffor chains look on tire chains.com get cross links every 2 links, they work a lot better. you can use float even on the gravel if it's hard /forums/images/graemlins/smirk.gif have fun /forums/images/graemlins/cool.gif )</font>
thanks for the info! i'll check with tirechains.com.
bruce
   / [b]TIRE CHAINS FOR PT 422?[/b] #8
Re:
Welcome aboard BruceL /forums/images/graemlins/grin.gif
We haven't had any snow to speak of here so I have no idea how my 422 will do. Last year we had around 24" but would you know it I didn't have the 422 /forums/images/graemlins/smirk.gif go figure.
Keep us up to date on your tire chain trek.
   / [b]TIRE CHAINS FOR PT 422?[/b] #9
Re:
"" the distance between the frame and the tires is minimal ""
Just Reverse The Wheels!!!!
/forums/images/graemlins/cool.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/cool.gif
   / [b]TIRE CHAINS FOR PT 422?[/b] #10
Re:
Hi Bruce. Welcome to the PT forum! You'll find a lot of help on here. I do recall seeing some information on chains when I was surfing prior to buying my PT.
As MR says, do a search and you will probably find what you are looking for.
Welcome! /forums/images/graemlins/smile.gif
FRONTIER MG20F LOT NUMBER 83 (A53084)
FRONTIER MG20F LOT...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A51572)
2014 Ford F-150...
2023 LMC M30018 LOT NUMBER 207 (A53084)
2023 LMC M30018...
FORD COBRA REPLICA RACING CAR (A52576)
FORD COBRA REPLICA...
2020 Ford F-250 Pickup Truck (A51692)
2020 Ford F-250...
CASE 580 SUPER N BACKHOE (A51246)
CASE 580 SUPER N...
