B series rear hydraulics error code 28-03
   / B series rear hydraulics error code 28-03 #1
yellowdogsvc
Platinum Member
S. Central TX Hill Country
I just sold my 2005 B series with rear pto and rear hydraulics. The new owner is getting the code 28-03 and can't get the rear hydraulics to engage. I'm not anywhere near him and don't have the service manual anymore.
Anyone with a B series seen that code? When I sold it, we checked everything and it worked. I'm thinking a relay went bad or a switch got disconnected. Front hydraulics work fine and PTO spun when we sold it and the dump bed worked fine too.
   / B series rear hydraulics error code 28-03 #2
28-03 is Diverter Solenoid Error Off. Could be wire connection, open circuit in the solenoid coil, or could be happening when oil is cold. This solenoid also has a position switch that verifies solenoid has activated and is diverting oil to the rear auxiliary, if oil is too cold the position switch doesn't move quick enough and the main controller sends the error code.
Try running the machine for a few minutes, raising loader up and down and triggering the front aux. button to send oil over relief to warm oil in that diverter valve then try engaging the rear.
Doxie. I will pass that info on. The machine worked fine in S. Texas but when he went north, started having problems. I appreciate the starting point to check things.
2007 International 4300 DT466 Refer Truck (A47384)
2007 International...
2005 JOHN DEERE 5205 TRACTOR (A51222)
2005 JOHN DEERE...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2006 International 4400 LP Ambulance (A50323)
2006 International...
IH Cub Lo-Boy 154 (A50514)
IH Cub Lo-Boy 154...
