B&S 25hp Intek v-twin
   / B&S 25hp Intek v-twin #1
bbbb
i just bout this engine model # 445777 to replace my worn B&S 18.5. I got evertthing bolted and lined up, fits great. the problem is the wiring is diferent. the new engine has a plug with
a red and orange wire spliced together i will assume it is alt. power
a green wire running from the low oil cut off switch
and that leaves a gray and a black wire that are running from the carb. float bowl.
the engine cranks and has spark, it will run if i pour gas down the carb. but the fuel pump will not work, i am assuming that it has something to do with the black and the gray wires running from the float bowl.
any ideas out there
   / B&S 25hp Intek v-twin #2
B, here is the link to the B & S web site. Maybe you can get some answers there. Good luck.
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A53117)
2025 K0311 UNUSED...
Vibratory roller attachment (A53421)
Vibratory roller...
UNUSED 20 in. Gasoline Chain Saw (A53117)
UNUSED 20 in...
Mini trencher attachment (A53421)
Mini trencher...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2016 Toyota Prius Hatchback (A53424)
2016 Toyota Prius...
