Price Check b 7500
   / b 7500 #1
klint
Bronze Member
B 7500,4x4,hydro,60 inc mmm,60 inch front blade,360 hrs,spotless tractor.Does $8500 sound like a good price?I have no dobt this is a good tractor but would like to here from guys who have used them.It will be used on my 5 acares to plow snow, finish mow 2.5 to 3 acares,brush hog,and use a tiller.Any thoghts?
thanks,klint
   / b 7500 #2
without a FEL I think it's about $2k too high...with a loader it is a fair price given the condition... but I am unsure of the value of the front blade...
   / b 7500
front blade is over $2000 new.Used tractors are expensive here in michigan.
   / b 7500 #4
I had a B7510 (pretty much the same tractor) and it was a great machine. The things you list will be good fit for the tractor. Depending on how much snow you get you might want to look into a 50-60" rear snowblower. Keep the blade on the front for smaller snows and use the snowblower for the big storms. The price sounds fair by standards here in Maine, but not a killer deal for sure.
   / b 7500
Im also looking at a deere 4010,loader,mmm,963 hrs for $9500.Id much rather have the loader than the blade.
   / b 7500 #6
I have a B7500 I bought 7 yrs ago. I change the fluids and filters more often than required, and have never worked on the tractor once since purchased new.
It has started first time every time except needed a new battery after 6 yrs.
The only problem I had was when it got over 100 outside, I noticed an occassional jerkiness of the steering. I'm sure hydraulic temps were too high.
I started using Super UDT fluid and problem disappeared.
   / b 7500
The 7500 is a nice tractor,but im leaning towards the deere 4010.I like there 2 pedal hydro and the loader would be great.I dont think the 3hp diffrence would matter to much sense most of the brush hogging i do i keep 3ft or less and the ground i want to till is soft.
   / b 7500 #8
I paid around that for a B7500 with a FEL/MMM combination this spring . Money well spent I am really enjoying the tractor . I bought the tractor from a local dealer with a good reputation so that factored into my decision .
Just a note when you remove the Fel ( or in your case the blade ) the tractor becomes a really nice mowing machine ! Power steering in great !
   / b 7500 #9
thanks,klint
What year? Price sounds high with no FEL. I have a b7610 and b7800 4x4s. Wheelbases are short and make for rough rides on uneven terrain. Plenty of power though. Also FEL makes good ballast for the bush hog- without FEL you might be doing wheelies.
   / b 7500
Im not sure what year.They only made them for 4 or 5 years.The deere is gone already so looks like the 7500.There is another one with 560 hrs no blade,has mmm for $7,250.Nice used tractors are $$ in michigan.I would buy out of state from a dealer off tractorhouse but have done that before and have been screwed over.
2015 FORD F-450 SERVICE TRUCK (A52472)
2015 FORD F-450...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2019 JOHN DEERE 5090M LOT NUMBER 93 (A53084)
2019 JOHN DEERE...
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A52472)
2008 V.E...
