b-6100e Kubota
   / b-6100e Kubota #1
rblantonjr
I am looking to purchase a small tractor and came upon a b-6100e with a landpride 48" mower for $4495.00 Is this too much? unknown number of hours. Tractor is in good shape.
   / b-6100e Kubota #2
Do you know the year and would this be a one owner tractor?
Thomas..NH /w3tcompact/icons/wink.gif
   / b-6100e Kubota
I am unsure of the year or the number of hours. If you have any suggestions I would greatly appreciate it.
   / b-6100e Kubota #4
You haven't given us enough information for anyone to give you an intelligent answer. If it isn't too old, not too many hours, it's in good shape, it's a bargain. On the other hand . . ., well, tell us something about it.
   / b-6100e Kubota #5
If you get a chance check the left hand clutch housing for a serial number.
The B6100E was introduce from 1976 to 1984..so you are looking at least 17 year old unit.
Does the B6100E come w/any other attachments..such as FEL etc..
If this a one ower tractor and looks in good shape also the mower..I would talk to the owner also take a test spin.
   / b-6100e Kubota
The only thing included with the tractor is a 48" landpride finishing mower. I have no idea on the number of hours, it has no tach or hour meter. The tractor is located at a dealership. Do you know if they make a FEL for this tractor.
   / b-6100e Kubota #7
I saw one for sale today for 2600 dollars. It didn't have
any implements...good condition..2-Wheel drive...14 hp
diesel PTO
   / b-6100e Kubota #8
Are you sure there is no hour meter? The B5100E's meter is under the hood next to the battery.
   / b-6100e Kubota #9
Whew...after many cups of coffee/w3tcompact/icons/crazy.gif I located some info they may help.
Yes a FEL can be purchase for a B6100E,and the FEL number B1630.
For more info scoot over to yesterdaystractors.com.
   / b-6100e Kubota #10
I've posted this information about my B7100D before, and I believe that it is true for the gear drive B6100s (B6100D and B6100E) as well.
For the gear drive B7100s, there WERE many attachments available when the tractor was new, such as mid-mower, FELs, front blades, etc. Parts for all of these implements still seem to be available.
The B7100 hydrostat model had a different design and would not use the attachments designed for the B7100 gear drive (that statement does not apply to 3-point equipment). The B1630 FEL (and the later B1630C version) was the FEL model that was also used on the B7100 hydrostat but would not fit the B7100 gear drive. I did a pretty thorough search and learned that NOBODY makes specialized equipment for the B7100 gear drive any more. There are 3rd-party manufactures that still make attachments for the B7100 hydrostat (such as a Woods FEL), but not the gear drive model. Unfortunately, a lot of the 3rd party manufacturers sales people don't know enough about the differences between hydrostat and gear drive Kubota B7100s, and almost sold me a FEL that would not have worked (I just happened to see the note about it not working on the non-hydrostat models).
Bottom Line: I don't think that you'll find a NEW FEL for the B6100 gear drive. You may be lucky enough to find a used one, though. In any case, if a FEL (or any other equipment specially designed for the B6100) is important to you, you might want to dig a little deeper and make sure that the equipment that is advertised as manufactured for the B6100 is in fact manufactured for the gear drive model and not the hydrostat model.
Kelvin
Peterbilt 377 Semi-Truck (A55218)
Peterbilt 377...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2013 Caterpillar AP500E Asphalt Paver (A52377)
2013 Caterpillar...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
Utility Trailer (A52377)
Utility Trailer...
UNUSED LANDHONOR BS-12-2500G BALE SPEAR (A54757)
UNUSED LANDHONOR...
