B 2920 Size of impliments
/ B 2920 Size of impliments #1
iplumb
Mason MI.
B2920
What size Brush hog, Tiller and Box blade is the B 2920 rated for? Anybody know? Thanks
/ B 2920 Size of impliments #2
I'm not sure what they are rated for but I bought a 60" KK tiller and it works fine. First pass you have to take it easy but the 2920 kicks butt on the second pass. I am very satisfied with the KK tiller. It could use a little better paint job but it is well built. I have 150 hours on my B2920 and it has been just great. I am planning on getting a 72" finish mower in a few weeks. I would probably only go with a 60" brush hog though.
/ B 2920 Size of impliments #3
I had a B7800 which has a few more HP. I used a 6' cheap rear finish mower on it and the RFM kept breaking on my rough and hill side yard. May have been OK for a flat smooth lawn. Barlows gave me what I paid for it on trade to a Landpride 6' RFM. I still have the Landpride and it's built like a tank. The B powered the mower with no problem and actually powered it better up the steep hills than the L3240HST which is twice as heavy as the B. The only problem with the B was when I reached the bottom of the hill and turned I could feel the (Landpride not the cheapo) mower sort of swinging the tractor. That was no problem because I knew it was going to do it and steered accordingly. I personally like the RFM because it lays the cut grass spread on the ground instead of in rows to the side and the easy hookup and disconnect. It also does a fine cutting job. Also easy to service (greasing and sharpening blades).
