Loader B 2650 power beyond with 3rd function and rear remotes
   / B 2650 power beyond with 3rd function and rear remotes #1
Dan33Klein
Northern,IL
B2650
Hi guys,
My new B2650 is on order and hopefully arrives soon.
I opted for the factory 3rd function valve to run a grapple. But I passed on the rear remotes due to the high price and the remotes being mounted up on the ROPS(terrible design IMO)
I am going to make the rear remotes myself using a 2 spool valve from surplus center.
Without rear remotes or 3rd function, there is a steel line that goes from the power beyond port on the loader valve, to the 3ph port. I was planning on removing this line and plumbing in the new remote valve in series as others has done. But it just occurred to me that the 3rd function valve will be in there also.
So when it is all done the hydraulic flow will be
Pump
Loader valve
3rd function valve
Rear remote valve
3pt hitch
Tank
Does this sound right??
Also, the power beyond hydraulic circuit of the tractor is protected by an internal relief, correct? There shouldn稚 be a reason for the new rear remote valves relief to operate since the whole system is protected by a relief. Correct?
Thanks for the help in advance.
Sorry for the long winded post.
   / B 2650 power beyond with 3rd function and rear remotes #2
You have the order of the components right, but make sure that your valve stack has a path to return to the reservoir, which is needed to divert and return any flow not being used by the implement/system when a valve is actuated open. This is important to ensure that the flow coming into the valve stack is balanced with the flow going out and not putting a load on the pump.
Thanks for the reply. I replied to a thread another member posted recently about adding rear remotes and I do not understand how his works correctly. He did not even use the power beyond port. He has a hose coming from the tank port of the new valve to the 3pt hitch valve. That tank port is supposed to be a low pressure line. Not high pressure like the power beyond port is. I do not know how his 3pt hitch even works now. When the 3pt sees resistance and builds pressure it is putting that pressure on the return portion of his rear remote valve.I am waiting to hear back from him. The kubota 3rd function valve only has two hoses, in and an out because the valve is rated to handle full pressure. I hope his continues to work fine for him since he is putting full pressure on the tank port of his rear remote valve
Thanks for the help
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2013 FORD Taurus (A50324)
2013 FORD Taurus...
43002 (A51691)
43002 (A51691)
New Holland B95 Backhoe (A50490)
New Holland B95...
2016 Ford Focus (A50324)
2016 Ford Focus...
