Axel Seal Leak
   / Axel Seal Leak #1
rjgman61
Hutchinson,MN
John Deere
Have a JD 4610
The axel seal on front tire has very small leak
Started after JD changed the axel fluid
Wondering if anyone has tried using stop leak, if yes what type/brand worked
It’s a very slow leak, looks worse because dust collects on rim
I know seal should be replace, which is plan if stop leak doesn’t work
   / Axel Seal Leak #2
talk to the dealer who did the work. the mechanic could have damaged the seal while installing it
   / Axel Seal Leak #3
I have changed such a seal on my 4WD John Deere. It was not too difficult. I would not waste effort with "little fixes", you'll spend more time later fusing over it, than wishing you'd replaced the seal in the first place.
   / Axel Seal Leak #4
I wouldn't put any foreign snake oil type stuff in the front axle.
First, find out if they used hydraulic oil or gear oil. Alot of times both are spec'd....so if the dealer used hydro oil....simply swapping to hear lube may solve the issue.
But that will only buy some time. The seal is failing and needs replaced
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
2023 INTERNATIONAL MV607 21FT ROLLBACK (A54607)
2023 INTERNATIONAL...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53473)
2024 BCL...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
