AWS and rotary tiller
   / AWS and rotary tiller #1
KennedyDiesel
Veteran Member
Central WI
Considering a 744 to replace my trusty 455. The AWS option never interested me on my 455 as they had smaller 24" tires and the rear steer lost a lot of ground clearance. The latest seem to have the same size tires so now it's a matter of how much ground clearance is lost with steering linkage. Also, how "wierd" is the AWS when tilling? Backing up to start a pass?
   / AWS and rotary tiller #2
I used an AWS for several years tilling and it has its pros and cons. Maneuverability was great in a small garden or a fenced in one. The rear steering linkage would drag in the ground but I never worried about it because I traded tractors every year. Tilling close to a sidewalk or something like that was tricky because a very small movement of the steering wheel would be compounded to the rear in the wrong direction. If you want to turn to the right the rear moves to the left. And what finally steered me away from AWS all together was several customers said that if I drove a straight line then their rows would be straight. That isn't an easy thing to do with an AWS.
That's kind of what I figured. Thanks for the reply.
Now if they had 3 selectable modes (2ws, crab, 4ws) wouldn't that be awesome???
(APPROX 25) UNUSED LANDHONOR PINS (A54757)
(APPROX 25) UNUSED...
(INOP) NEW HOLLAND TS6.120 TRACTOR (A54756)
(INOP) NEW HOLLAND...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
2024 Kubota KX080-4 Midi Excavator (RIDE AND DRIVE) (A50775)
2024 Kubota...
2008 Featherlite Trailer, VIN # 4FGE853218C108480 (A53424)
2008 Featherlite...
UNUSED LANDHONOR TP2-13-08D HYD TREE PULLER (A54757)
UNUSED LANDHONOR...
