Auxiliary Services Control Valve
   / Auxiliary Services Control Valve #1
HiTech Redneck
Hi! I have a 68 Ford 2000 3 cyl,live pto,6 speed.Under the seat is an auxiliary services control valve.Do these operate ok for a remote cylinder? I found out from this site that the pump capacity is small for something like a wood splitter(I have a gas one)but would I be able to operate a 3ph grapple that I would like to copy from a design found on the net? Does anyone have a picture of this valve with the hoses connected? It seems some elbow connectors & such would be used to direct the hoses back to the cylinder?Are there any other suggestions of what else I might operate with this valve?Thanks for any information you may be able to provide!!
   / Auxiliary Services Control Valve #2
Not really. You would be far better served to replace the Aux. Services vavle with a remote control valve to be able to control a double-acting remote cylinder to operate the grapple. The aux svcs valve enables you to direct hydraulic pressure as follows:
Closed (pushed full in) - to the 3-pt lift cylinder only. Mid Position - lift cylinder and aux. svcs. port. Full out - to aux svcs port only. This will only operate a single-acting cylinder.
Hi! Thanks for your reply.I was mainly interested if the operation of this valve would be useful or more of a pain. I'll look into another valve like you mentioned.Thanks again for your time!! Don
Quick Hitch Skid Steer Attachment (A51691)
Quick Hitch Skid...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2013 Kenworth T800 T/A Dump Truck (A53117)
2013 Kenworth T800...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
