Argonne
- Joined
- May 21, 2005
- Messages
- 280
- Location
- Paris, TX
- Tractor
- JD2210, Ford 4400, Case IH 685, Terramite T7, JD 6x4 M-Gator
I need to install rear hydraulic ports on my 2210 to serve a new implement that has it's own SCVs. JD says they have the second SCV kit for the 2210, but nothing to add a simple set of ports to serve implements with their own valves. This implement (a McConnel Swingtrim) also has a hydraulic motor that needs a low pressure return line. Below is a simplified diagram of the hydraulics showing connection requirements. (I have plenty of other diagrams if someone needs more info).
I know little about hydraulics (yet), and I'm hoping that someone can put me on the track of a kit that I can install myself, or put me in touch with an aftermarket resource that can sell me what I need without breaking the bank.
I have the tech manual for the 2210, so if it turns out that I will need to do this peicemeal, a description of what ports to connect the lines to would be great too (but I'm hoping there's a kit out there).
Thanks in advance.
Thanks in advance.
