Auxiliary Hydraulic Question for my B2100
   / Auxiliary Hydraulic Question for my B2100 #1
MAMtractorguy
I just bought a used front mount snow blower (B2660) for my B2100. The snowblower frame that came with the snow blower has a hydraulic lift. I have never used an implement with hydraulics with this tractor and I have a few questions. I know I need to purchase a compact single spool hydraulic valve, and I will purchasing one from my local tractor store this week. According to my manual I also need to purchase a hydraulic outlet cover for either the mid or rear outlet. I have located the rear outlet on my tractor but I can't seem to find the mid outlet. It is not where the drawing in my manual says it is. Where would it be located? Or do I not have one? Ideally it would be nice to use the mid outlet because it's a front mount blower. Also does anybody know the part numbers for both the rear and mid outlet cover kits? I don't have a Kubota dealer near me and I want to see if I could purchase the outlet cover online. Thanks for your help.
   / Auxiliary Hydraulic Question for my B2100 #2
Welcome to TBN:D
I can help with the hydraulics in general but I am not familiar with your tractor-but it sounds like youv'e got a handle on what needs to be done.
One suggestion I would like to make is to at least put a 2 spool valve on your tractor, if not a 3 spooler. It's the same amount of work-and only cost's a few dollars more. Then you can add hydraulic chute rotation to your new blower:D
You can probably get a small 3 spool valve like this from the SurplusCenter for what your where going to pay locally...
2000 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A49461)
2000 Ingersoll...
2013 DOOSAN G25P FORKLIFT (INOPERABLE) (A50854)
2013 DOOSAN G25P...
2016 John Deere 35G Mini Excavator (A49461)
2016 John Deere...
2012 MAGNUM TRAILER (A50854)
2012 MAGNUM...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
