Auxiliarly Lights - How big is my alternator?
   / Auxiliarly Lights - How big is my alternator? #1
bcarter
Eastern MA
Kubota B2710
I've been doing my homework regarding the installation of additional lighting on my 1999 Kubota B2710... There are tons of great ideas in the various threads on the subject but one thing that was mentioned several times and not discussed in detail was the required size of the alternator. Obviously the "current" current load plus the "new" current load must be less than the output of the alternator, but how do you determine the output of the alternator?
I've checked the docs that came with the tractor and I've done some searching through the threads here but I haven't found anything on how to determine how "big" my alternator is. Does anyone happen to know what size alternator comes standard on a B2710? Alternatively, does anyone know how to determine alternator output?
For folks with a B2410, B2710, or B2910 - how many watts of auxiliary lighting have you added?
Thanks in advance...
   / Auxiliarly Lights - How big is my alternator? #2
Look in the specs section of the Kubota brochure or it is usually marked on a plate on the alternator. My L4310 has a 40Amp alternator. More than enough for lites. A 55watt lite draws about 4.5 amps.
Rich
Thanks for this feedback... I actually thought of both of these, but didn't find what I was looking for. The alternator itself had no markings on it at all...and I don't have a Kubota brochure (although I thought I saved the one I got when I bought the tractor...)
I was hoping that another B2710 owner might already have this information. /forums/images/graemlins/grin.gif
I figured that a 40Amp alternator would be more than enough for what I want to add... My guess is that I have a 20Amp alternator and if so, I'd be pushing the limit if I added 3 or 4 55 Watt lights.
   / Auxiliarly Lights - How big is my alternator? #4
Bill,
The standard alternator (dynamo) on a B2710 is probably more in line with 10-15 amps. I can't remember the exact output, but it isn't much. I was in the same quandary as to how to add additional lighting. The first thing I did was upgrade the factory headlamp bulbs with 55 watt bulbs. For my auxiliary lighting, I used two 55 watt magnetic worklights that can be attached to just about any metal surface on the tractor. (top of rops, under rops, side of rops, loader arms, etc) I used the factory auxiliary hot wire (on the right rear fender wiring harness) to install a cigarette lighter in the plastic toolbox under the seat. Now I can plug in my auxliary lights separately and not overload the electrical system. The other choice is to purchase the optional 40 amp alternator from Kubota ($150.00-175.00?) if you want to add more than just two additional lights.
Good luck on the project,
Mike
   / Auxiliarly Lights - How big is my alternator? #5
Just check the fuse in the circuit you want to tap into. Mine was 15 amps. Multiply that by 12 volts and you get the total watts that circuit can handle (i.e. 180 watts). Since my headlights are only 24 watts each, I still had plenty of amperage to power two 55 watt lamps on my ROPS.
   / Auxiliarly Lights - How big is my alternator? #6
If the alternator that kubota is sticking on those tractors is only 10-15 amps... they are a ripoff... heck.. dc generators kick up to 20 way back from the 1950's.. and If I were in that low output range.. i would much prefer a dc gen to a low output alternator.
Glad my stock NH alternator isn't in that same class of charging units.. reminds me of those little jobs on bikes for running a headlight or something.
I realize that they only need to charge a battery, and run some lights.. but considering everything else on a tractor is usually beefy and 'over-rated' for its designed purpose.. you would think they could have pony'd up for a hary chested el-cheapo 30 amp job.. heck.. probably the cheapes alternator you can buy is a delco 10si... and that is waht 40-45 amps?
Things like companies scrimping in areas they think you wont notice is what really burns me these days.. that 'just get by' attitude... In the old days stuff used to be 'value added'.. guess those days are gone...
Soundguy
   / Auxiliarly Lights - How big is my alternator? #7
According to the WSM the dynamo output on the 2710/2910 is 14-15 amps at a dynamo speed of 5200 rpm. The no load voltage should be 14-15 volts.
Based on this it would appear that a full load of lights plus normal electrical loads just might drain the battery faster than it can be recharged.
The manual also quotes "This dynamo produces higher voltage in slow speed rotation, and charges electric current to the battery during engine idling."
   / Auxiliarly Lights - How big is my alternator? #8
</font><font color="blueclass=small">( According to the WSM the dynamo output on the 2710/2910 is 14-15 amps at a dynamo speed of 5200 rpm. The no load voltage should be 14-15 volts. )</font>
It is the same for my BX2200.
</font><font color="blueclass=small">( Based on this it would appear that a full load of lights plus normal electrical loads just might drain the battery faster than it can be recharged.)</font>
Sure seems that way! I wonder what the normal load without lights is on these tractors? Probably not too much.
</font><font color="blueclass=small">( The manual also quotes "This dynamo produces higher voltage in slow speed rotation, and charges electric current to the battery during engine idling." )</font>
Yeah, isn't that an interesting quote. It raises more questions than it answers. It would be nice to know how the 5200 rpm corelates to actual engine rpm. /forums/images/graemlins/confused.gif
At any rate, I'm going to be pretty careful with my use of lighting during snow removal this winter. Or maybe I'll just splash out for the optional 40 amp alternator. /forums/images/graemlins/frown.gif
Mike,
If this is what you are currently running for lights then the total is 220 Watts (2 55W headlamps and 2 55W auxiliary). Mr. Ohm says that this is 18-19Amps if you run everything at the same time. Do you run everything at the same time? If so, have you had any problems keeping the battery charged?
I'm looking at adding 3 35W auxilary lights which should be about 9 Amps plus what ever the stock head lamps draw. If you have no problems with 18A, I shouldn't have a problem with 9.
If you only run the headlamps OR the auxiliary lamps (mutually exclusive) then I think I'd still in pretty good shape as far as current draw from the alternator...
Thanks,
Jim,
This will only tell me if I've got enough "room" in that particular circuit. The alternator may not have enough "umph" (that's a technical term... /forums/images/graemlins/grin.gif) to drive all of the circuits that I have access to (or even "all" of one circuit). If, as has been suggested in other posts, I only have a 10 amp alternator, this theory wouldn't hold true...
However, if you're running the stock alternator on your BX22 and you can run the stock headlights plus 110W of additional lighting with no problems keeping the battery charged - I should be OK as well.
2007 STERLING L9500 TANDEM AXLE DAY CAB (A52141)
2007 STERLING...
Test Button (A47384)
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
