Auxilary remote Hydraulics on a 4220 for $435 ??
   / Auxilary remote Hydraulics on a 4220 for $435 ?? #1
trs
Bronze Member
Georgia & Florida
Branson 4220
Is it worth $435 for 1 set of remotes.. about the only thing I might use it for would be a wood splitter, is it easy to add later as I will have a backhoe on tractor with hydraulic lines running to it.. was also looking at 4720 but was told the extra 5hp would not help any with the backhoe as it is run off the hydraulics, so the 4220 looks like it would do the job and $1100 for 5hp seems a bit to much.. heck i can buy a 5hp briggs & stratton for $200 /forums/images/graemlins/grin.gif
   / Auxilary remote Hydraulics on a 4220 for $435 ?? #2
If your quite handy..maybe its not a great deal. I got them and I'm glad I did. You get the remotes and the remote activator under the seat as well as the trailer connection.
Your call..
I am pretty handy.. just put my 4 post 9000 lb Bend pak auto lift togeather and it only took me 3 tries to get it right.. /forums/images/graemlins/grin.gif had to borrow a bobcat with forks to set the ramps.. the instructions were lacking.. I could do it in half the time now.. I think I will wait, then if I need the remotes, I'll do it myself..
   / Auxilary remote Hydraulics on a 4220 for $435 ?? #4
Yep that works for you...I'm handy too...didn't know diddly about tractor hydraulics...already dropped 17K whats another 400 bucks??
Didn't want to screw with my tractor right away...wanted to use it.
   / Auxilary remote Hydraulics on a 4220 for $435 ?? #5
You can raise the FEL and disconnect the hyd hoses and then hook up the hyd hoses to the fel controls. Kinda of rigging it but that is what I plan to do to operate my wheat drill which has a hyd cylinder.
   / Auxilary remote Hydraulics on a 4220 for $435 ?? #6
If you need to use the loader hydraulics for an extra rear remote, I've found that using the tilt segment works best. That way you can still raise and lower the loader, and you don't need to connect/disconnect the hoses under pressure, especially if you take the bucket off first.
2019 CASCADE DM0B1300 HYD BALE CLAMP (A51247)
2019 CASCADE...
RIDGID K-400 POWERED DRAIN CLEANER (A51248)
RIDGID K-400...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
CONTACT INFO (A53084)
UNUSED FUTURE HYD WOOD DRILL (A51248)
UNUSED FUTURE HYD...
UNUSED WOLVERINE GB-11-72W-72" HYD GRAPPLE BUCKET (A51248)
UNUSED WOLVERINE...
