Automatic Glow Plug Operation (L4200)
   / Automatic Glow Plug Operation (L4200) #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
I've always wondered if my glow plugs are working on my L4200. It supposedly engages the glow plugs automatically if they are needed when you turn the key on. I have not used my tractor in the winter until this year, so I don't have much experience with the operation. I have noticed the glow plug light going on when it is cold (30Fs), but it only stays on for a couple of seconds at most. Would engaging a glow plug for 2 seconds even do anything?
My tractor has always started up after a few seconds of turning regardless, but I worry about getting it going when it is really cold later in the year (if something isn't working right).
JayC
   / Automatic Glow Plug Operation (L4200) #2
My L4200 would glow longer in cold weather. It never failed to start right up. If you worried just turn the key on and then off and on again to get it a extra boost. At about 500 hours my L4200 glow plugs got a mind of their own! They would go off and on anytime and in any weather. I called Kubota and they said it wouldn't hurt the engine. It was a module that gets funky in them and turns it on and off for during use. My L4200 started great all the way down to 20 degrees. When it was colder than that I had the sense to stay in the house!:D
   / Automatic Glow Plug Operation (L4200) #3
... it only stays on for a couple of seconds at most.
JayC
That's the way they work.. and like bilrus said, when it's really cold give it another cycle or two...
......At about 500 hours my L4200 glow plugs got a mind of their own! They would go off and on anytime and in any weather. I called Kubota and they said it wouldn't hurt the engine. It was a module that gets funky in them
That's the controller, there is a diode that fails in it ... and causes intermittent problems... It will over time give your glow plugs additional hours and lead to their failure, but that's going to take a while...
That controller is inside the dash near the relay. and it's a little over $70...
Someone on here was going to just do away with the auto system and put a push to heat button on... don't know if it was done or not. That would be the simplest fix... just have a push button actuate the relay... KennyV
'Kay - I started up the beast Saturday, after sitting for a couple of weeks, and after a nice freezing cold night. I turned on the key and the glow plug light stayed lit for about 5 seconds. I turned the key, and it started about halfway through the first crank. "ShhhVOOOM..." It was a bit clanky for the first second or two, which I suppose isn't too abnormal - and it sure starts good for a 2500 hour machine.
JayC
So, it is yesterday (3 weeks after starting this thread), and I started up my L4200 after it was sitting a week, just to stir it up for a minute or so. It was cold, but not outrageously cold... ~25F or so. I got no glow plug light when I turned on the key. The tractor cranked for a long time, probably close to 10 seconds, before kicking over and firing up. It seems that my glow plug automatic thingie crapped out on me. Unfortunately, I don't know how to diagnose and address that system. Any and all suggestions and/or directions would be appreciated.
JayC
   / Automatic Glow Plug Operation (L4200) #6
Hello JayC...
There is a relay and a controller UNDER the removeable dash.
They are both on the right side, mounted together.
The controller is the normal thing that fails its around $70...
You could just replace it with a push button to apply 12 volts to the coil of the glow plug relay... (thats what I will do if my controller fails again).
Heree is a picture of the controller that Kenonf posted... http://www.tractorbynet.com/forums/...-controller-l3600gst-glow-plug-controller.jpg
If you need the wiring diagram it's here... http://www.tractorbynet.com/forums/kubota-owning-operating/134518-glow-plug-wiring-help-needed.html
At post #6...
KennyV
   / Automatic Glow Plug Operation (L4200) #7
After looking at the wiring diagram again... You will not apply 12 volts to the glow plug relay coil... You will apply ground to the GP relay coil ... it has 12 volts applied whenever the key is on, the controller normally supplies the ground for the coil... so if you were to replace the automatic controller with a push button you would only have to apply ground with the push button ... easy change over... KennyV
   / Automatic Glow Plug Operation (L4200) #8
Thanks for the info Kenny, Ill keep this in mind if mine fails, I usually cycle my key 3 or 4 times in the freezing cold and it fires right up.
Mike
   / Automatic Glow Plug Operation (L4200) #9
Wondering if any one has opened the relay after failure, in order to see if it can be repaired...Ie." the diode failed"? Personally I have no trouble reverting back to a push button and counting. My tractor has the reversing igniton switch activation for glows.. Jy.
I figured I'd revive this thread - I FINALLY addressed my dead glow plug problem this past weekend after it being broken for two years. Relay is good (opened it up - nice relay), thermistor was good, so it had to be the controller. I pulled the controller out, then used the existing socket to bypass the function. I shorted the center two leads together on the controller's 6-pin socket using blade connectors ('out to relay' and 'out to indicator light'), then ran that line through a momentary switch to ground. Push button when key is on, glow plugs are activated and yellow indicator light goes on. Sweet. If I ever want to replace the module, I just pull out the blade connectors and plug a new module in. I can't imagine I ever will though...
I still don't understand what the diode-or circuit (that come out to the center pins) does in the module - rather than just shorting them together - I suppose it would prevent a potential back-feed through the bulb, but so what? I don't see it happening. It seems that the diode-or would transfer the inductive kick from the relay energizing coil (and it does give a kick - enough to arc) onto the internal transistor, rather than to the light bulb, which seems exactly what you don't want to do. Perhaps there is a non-shown zener on that pin in the controller? Maybe a snubber of some kind? I was thinking of putting a cap (like a 0.1uF) across the switch - that act as a snubber with the bulb and would absorb the relay's inductor energy when the switch is released. What do you think?
JayC
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2019 CATERPILLAR 262D3 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
PETTIBONE B66 EXTENDO (A51222)
PETTIBONE B66...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A52128)
2021 John Deere...
Mini Excavator Attachments (A49462)
Mini Excavator...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
