Automated Chainsaw Mill
   / Automated Chainsaw Mill #1
wasabi
Platinum Member
Cullowhee Mountain, NC
PT2445 and PT1850
I have looked at the bandsaw and circular saw mills and keep returning to the idea of building a cost effective chainsaw mill. Surely there must be a straightforward way to automate such a rig. Anyone have any success with such an idea or have any links to share?
Thx, Sabi
   / Automated Chainsaw Mill #2
Would you care to elaborate a bit on what you are thinking about? "Automate" is a bit confusing as to what you have in mind. Its an interesting idea, and maybe someone can help without any more information.
   / Automated Chainsaw Mill #3
wasabi,
There are a couple of "mills" that use chainsaws.
Search the Internet for "Alaskan" mills and you will get some hits.
There is also a company, Logosol, that makes a more substantial
mill. You can find them at <A target="_blank" HREF=http://www.logosol.com>http://www.logosol.com</A>.
I have seen speed tests in magazines comparing Logosol mill with
the bigger mills and the come in last in terms of production. But
they also only cost about 3,000 dollars. I have seen the product
demonstrated at a show and was very impressed. If I had the money
I would buy one. But I don't have the money. /w3tcompact/icons/smile.gif
Hope this helps...
Dan McCarty
Clearly the alaskan and granburg sp? saw attachments work, with the right combination of power and chain tweaking, but for this fifty year old, I don't see bending over and pushing a chainsaw as a healthy or back-friendly activity. I've seen some attachments that use the saw vertically, which makes a bit more sense to me. Now if the pushing/feeding part could be automated, it might take enough of the ooumph factor out of it to make it a doable, productive arrangement. (I'm really not daft enough to want to reinvent the obvious, but, on the other hand, don't see any point in paying high frieght and manufacturing bills when I'm basically gonna have to assemble the parts that they ship to me anyway.)
So here is the basic vision, unabashedly inspired by others sold elsewhere at high prices:
Build a fixed, (wood?) frame low to the ground that the log is dragged up to (with the new tractor, of course) and then pushed, and rolled onto with a peavy. A solidly-built pipe or welded angle iron frame box with v-wheels (pulleys might work?) would ride along the edge of two long angle iron rails, solidly secured to the wood frame, kinda like railroad tracks. The pipe frame arrangement would hold the saw bar top and bottom in a vertical configuration with a sideways adjustment mechanism (wormscrew?) to allow for thickness adjustment. Some sort of dog-type mechanisms would hold the log steady and securely, perhaps rigged from modified sliding clamps.
The feeding part is what I am not too clear about. I guess it could be a very long threaded rod that worked like a wormscrew, but probably easier would be some sort of cable or chain geared arrangement that could be powered by an off the shelf electrical motor, perhaps with variable speed.
Then (in theroy) the log is loaded and secured, the saw width adjustment set and locked, the chainsaw is fired up and the feed motor activated. I, in the meantime, stand back with the remote, sipping a cold one and monitoring the saw's progress. At the end of the run, the slab falls of its own weight and can be pulled safely aside. The width adjustment is reset, the log turned as needed, and we go back through it again.
Anyway, that's the short version. Am I nuts?, or do you think this would be worth the effort. I've got many trees, a thirst for more lumber than I can pay for and an aversion to burning it all when I know it can be turned into lumber. I would also like the convenience of a small mill to custom size materials as available. Drying sheds, proper sticking, a solar kiln and patience would complete the picture.
   / Automated Chainsaw Mill #5
You could use a looped chain, like the chain in a hay elevator. That may you could reverse the feed to pull the log back after the cut. If you made the bed long enough, you could cut in both directions with the chainsaw mill. You would have to figure out some way to get the chain to grab the logs, but it souns like your idea would work.
Good thought Ed. I think making the track long enough to make runs both ways definately makes sense, but, rather than trying to muscle the log around, I'll rig it to move the saw back and forth across the stationary log held by dogs.
   / Automated Chainsaw Mill #7
Baileys catalog might be something you want to look at.. they have some of those vert bar attachments, you just nail a straight and true 2x4 to the log.. having previously struck your chalklines, adjust the bar attachment, and walk the saw down the log.. of course, you'll need to hold the log off the ground, and you MUST use rip chain, not crosscut.. since you are ripping with the grain. Fortunately, Baileys sells that too.
I found my lil Alaskan mill makes short work of this eastern red cedar, for red fence posts and also slabs that I can rip and cross to square and nearly S4S (surfaced four sides) that only needs a quick lick of the belt sander for full 4/4, 6/4 and more, lumber.
I love livin here, the pine goes for big bucks and I can get all the hardwood I want, cheap !
   / Automated Chainsaw Mill #8
In that case, you could go with a long motorcycle style chain. Hook either end to the saw holder, have a gear on either end. Use a reversible electric motor and a pulley and belt to hook it to one of the gears. If you use pulleys like those in a drill press you could even vary the speed depending on the size and hardness of the lumber you are milling. Also with the pulley and belt you will have some slippage in case the saw stalls or binds for some reason.
   / Automated Chainsaw Mill #9
I see lots of sawdust sticking to chains and worm gears and gumming everything up. Do you have any ideas on controlling that?
   / Automated Chainsaw Mill #10
You could put a chain guard on, kind of like the ones on the older bicycles. Have it on top on the top on the upper and lower section of the chain. That should keep most of the sawdust out of the chain.
STORAGE FEES (A52141)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
Wolverine Quick Attach Screening Bucket (A50515)
Wolverine Quick...
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
