Mowing Auto PTO on RK37
   / Auto PTO on RK37 #1
Fine409
RK37 Hydro Cab
I bought my tractor last fall and have used the loader, Backhoe, and rear blade. I’ve now assembled and installed my rear finish mower. I have a auto pto button on the dash as well as a pto button. What does the auto button do? I can’t find it in anything that came with the tractor.
   / Auto PTO on RK37 #2
If it's anything like the RK55 (and I'm assuming it's the same), while it's in auto, the mower will stop when you back up, then engage again when you move forward. I believe it also disengages when you take it out of gear or on my shuttle shift, when you depress the clutch. I leave mine on manual because I do a lot of cutting while backing up. But for a large field or something, auto may work better.
   / Auto PTO on RK37 #3
From page 2-15 of the Operator's Manual:
2 - 15
DESCRIPTION OF TRACTOR CONTROLS
I ndependent P T O
operation switch
(1) Operation of PTO selection
switch
「OFF」- The PTO shaft is stopped.
「Automatic」
When the implement is lifted to
the preset height, the PTO shaft
is automatically stopped.
「Manual」-
The rotating status of the PTO
shaft can be controlled by operating
the PTO ON/OFF switch to
the ON/OFF position manually.
► (3) PTO operation indicator
ON - The PTO shaft is rotating.
OFF - The PTO shaft is stopped.
RH3O214B
(2) Operation of PTO ON/OFF
button switch
Operation for 'automatic' and 'manual'
positions of the PTO selection
switch is as follows :
「ON」
When pressing the switch, the
red lamp comes on and the PTO
shaft rotates.
「OFF」
When pressing the switch again,
the lamp goes off and the PTO
shaft stops rotating.
https://www.rktractors.com/manuals/Operator Manuals/RK37 Hydrostatic Open Station & Cab Tractor.pdf
   / Auto PTO on RK37 #4
I cant figure out how to set the auto PTO height
Bundle of 40 Gauge Pipe (A50860)
Bundle of 40 Gauge...
Brown BDH-750 Disc Harrow (A50490)
Brown BDH-750 Disc...
2011 Ford F-150 Ext. Cab Pickup Truck (A48081)
2011 Ford F-150...
Load Master 27ft Tri-Axle Boat Trailer (A48082)
Load Master 27ft...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
Big Dog Stout MP Zero Turn Mower (A50860)
Big Dog Stout MP...
