You might find it useful to see if your local building department has ‘tip sheets’ on building pole barns up to a certain size w/o the need for engineered plans-Spokane County (WA) where I recently built a 40x60x14 pole building has such covering buildings up to 30x30 iirc. They have them on line and you can use the sketches and details therein to obtain your building permit-details include pole size, footing diameter and depth, truss details, pole spacing, girt and purlin spacing and size etc.
Good source of info on pole buildings meeting WA and Spokane County residential building code-could be a reasonable starting point if your local authority does not provide something similar-if you can’t locate it send me a pm and I will send you a copy.
