Auger Feed on JD Balers.
   / Auger Feed on JD Balers. #1
R W
Does the Auger Feed on John Deere balers perform OK in most types of hay.
   / Auger Feed on JD Balers. #2
Performs great in almost all kinds of hay. The John Deere balers are considered benchmark units. Some other balers are as good, but I don't know of a better one of the same style.
Ken
   / Auger Feed on JD Balers. #3
Note: the auger can float up as it drives the hay into the feeder forks. This gives the hay stream to the bale chamber a compacted density that leads to consistent bale formation, especially with very fine grasses found in 3rd cutting (for example).
I often run the baler stationary to rebale busted bales, loose hay and unrolled round bales. The feeder system is safer for me, too. The auger drive has shear pins to prevent a blockage from ruining the machinery.
   / Auger Feed on JD Balers. #4
As a note, the only time my JD clogs is if the pickup protection (belt slip) kicks in when a huge clump is caught between the pickup and the pre-compressor/control tines above the pickup. I think the newer ones have a different system for that but its only happen to me a couple of times when we missed first cut and cut late for second.
Thanks for your replies, appears the auger feed set up on JD balers must
work much better than it did on early Internationals.
   / Auger Feed on JD Balers. #6
Yes they do, a neighbour has an old IH and it used to wind hay into the auger.
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
2016 RAM 3500 HD SERVICE BODY TRUCK (A53426)
2016 RAM 3500 HD...
2025 Forklift Safety Basket Attachment (A51691)
2025 Forklift...
2015 Freightliner Bucket Truck - Terex TM 100 Boom - Cummins Diesel - Allison Transmission (A53473)
2015 Freightliner...
2021 Polaris RZR 1000-4 (A52384)
2021 Polaris RZR...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
