Auger/cement mixer skid steer attachments
   / Auger/cement mixer skid steer attachments #1
Sun Treader
Western Virginia
Case IH 495
No one has ever seen one of these in action or has an opinion?
Hydraulic auger that will also mix cement and using the loader be able to carry it from mix site to use site or even lift it up to pour wall forms or group CMU?
   / Auger/cement mixer skid steer attachments #3
I laid quite a bit of mixed concrete with a plug in cheapie mixer then dumped that into my skid steer bucket to take over to the pour. That unit is quite picey unless you have a daily or weekly use
   / Auger/cement mixer skid steer attachments #4
This is why the hydraulic units aren't very popular- the little electric mixers can be had at near throw away prices and are easily moved by hand.
If you need more "control" than a standard bucket they make concrete SSQA buckets.
I'm working with a little electric mixer and its a great unit, no question there. I've rented mortar mixers when I had enough mortar to keep it busy. We're grouting a CMU wall now and with the electric that involves mixing, wheel barring, and then lifting buckets up to place. My thinking with a loader mounted mixer is it could lift and place directly without all the heavy labor. This is all just person stuff playing around the farm, no where near commercial, daily, or even weekly use.
The Danuser type horizontal auger mixer and placement buckets would be ideal but they're $5k. I'd also like a hydraulic auger for regular hole digging. This unit isn't much more expensive than a skid steer type hydraulic auger alone and you get a versatile way to mix, carry, and place as well. Might work for my uses, but lots of better solutions for more frequent users.
2014 MACK GU (GRANITE) (A45046)
2014 MACK GU...
CHECO HYDRAULIC GREASE INJECTION UNIT (A45333)
CHECO HYDRAULIC...
1965 Correct Craft Wildcat Boat and Trailer (A44391)
1965 Correct Craft...
New/Unused 20ft x 30ft x 12ft Storage Shelter (A44391)
New/Unused 20ft x...
2020 FORD F-350 (A45333)
2020 FORD F-350...
Onsite begins 8:30am / Online begins 9:30am (A44501)
Onsite begins...
