ATV winch switch for 3rd function
   / ATV winch switch for 3rd function #1
bigballer
Platinum Member
PNW - North Central bWashington - The Evergreen St
2006 Kubota L3400
   / ATV winch switch for 3rd function #2
It depends on which solenoid valve you use.
This valve is a diverter valve to switch the curl function from curl to grapple. FEL valve joystick will control the grapple or curl. Curl is default mode, no power to solenoid.
Surplus Center - 12 VDC 13.2 GPM SAE 8 DOUBLE SELECTOR VALVE
This solenoid valve will switch the valve to cause the fluid to go to the base end or the rod end, with full force, no feathering. Need a sub plate also.
Surplus Center - 12 VDC 10 GPM OC DA SOLENOID VALVE
Surplus Center - 1 STATION DO3 SUBPLATE OPEN CENTER
http://www.surpluscenter.com/Wire/W9-6136.jpg
LINDE WELDER (A53843)
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2005 CATERPILLAR 730 OFF ROAD WATER TRUCK (A51406)
2005 CATERPILLAR...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
WB Mower (A50120)
WB Mower (A50120)
GooseNeck Trailer (A52377)
GooseNeck Trailer...
