Attacked by a branch
   / Attacked by a branch #1
patrickg
Veteran Member
South Central Oklahoma
Kubota Grand L4610HSTC
So there I was this last weekend killing a little time brush hogging thickets, taking out a few juniper trees (AKA cedar in Oklahoma) the odd oak sapling etc, when I noticed the temp gauge starting to climb significantly above its normal reading. Not over heating just beginning to run hotter and hotter. I stopped to clean out the screens in front of the radiator and A/C condensor as weed seeds/fluff/junk accumulates and the temp begins to rise and the A/C begins to get mediocre. After cleaning the temp ordinarily returns to "Normal" immediately. However, this time the lil Kubota wouldn't start, wouldn't even turn over, wouldn't engage the starter... I was more upset than just having to walk a half mile back to the house, I needed the tractor for a fork lift to unload the steel trusses Monday (today) from a 18 wheeler. Eventually I notice a 3 1/2 foot long by
1 3/4 inch thick branch impaled in the engine compartment where the clutch pedal arm is, next to , dare I say it, the starter!
Try as I might I couldn't pull the stick out so I walked the half mile back to the shop for a comealong and a rope and a wife to drive the pickup when I got the tractor running (note confidence). The comealong broke the rope that I tied to the branch. I doubled the rope and broke it again. Changed ropes and pulled the stick out. I thought maybe the clutch-has-to-be-down-to-start switch had been interfered with and it would now start... NO JOY. I felt around the starter with my fingers and found a loose wire and when I pressed it into the side of the starter it went "SNAP" and seemed to hold there. The tractor cranked right up and I unloaded the steel trusses this evening, mostly after dark (love Kubota's work lights).
Anyone use skid pans or other "Armor" added to their tractor?
Patrick
   / Attacked by a branch #2
<font color=blue>Anyone use skid pans or other "Armor" added to their tractor?</font color=blue>
There is more than one thread that addresses this topic. One I was just looking at is <font color=red>Bullet proof BX</font color=red>.
I haven't "bullet proofed" my tractor, but after reading about your experience, I'm a little more inclined to try.
OkieG
   / Attacked by a branch #3
You bet. I do a lot of brush hogging and I have armored mine from the front axle to the draw bar. It protects the driveline and all the hoses and linkages.
   / Attacked by a branch #4
Those branchs are sneeky, I was out last year doing basicly the same thing when one snuck up into the engine and took a bite out of the fan belt. Made it back to the house with the engine just starting to get really hot. New belt and everything was fine.
   / Attacked by a branch #5
It can be much worse. When I first bought my property, it was covered with sumac and small saplings. So my stepdad brought his tractor and brushhog out. The tractor, a Massey 65 I think, had an oil filter mounted low. One of the saplings managed to catch the oil filter ,break the seal and dump all the oil. Next thing I know the tractor quits. The short story was about $1200 damage to the engine.
One thing I specifically looked for when I bought my tractor was how low the oil filter was.
   / Attacked by a branch #6
While mowing my way overgrown pasture this year I became worried about all of the 1/2" and 3/4" weeds I was cutting finding the radiator, so I made a bumper / grill gard using perferated metal... It is smaller than expanded metal.. the holes are about the size of bb's. Worked great...I used to pull sticks out that made it dangerously close to the radiator.. but no I would have to head on a spike to get a puncture.
Soundguy
   / Attacked by a branch #7
I busted my power steering hyd lines twice - then put on a skid plate -it helps but you still gotta watch - particularly when backing -- I had one come over the back of the skid plate - all the way forward and depress my clutch pedal for me - I was stuck right there til I could get it out and straighten the clutch linkage.
Thanks everyone for sharing your experiences!
Mike, That sounded like a devious branch.
A real weak point in the Kubota L-4610 is the guards in front of the rubber boots over the steering component thingies near the left and right ends of the front axle. They don't protect the rubber boots hardly at all and they get bent all too easily. I bought a set of new ones and they are bent worse than the originals. I am going to weld the old ones and new ones together to get more thickness/strength and to make them longer to cover the rubber boots better. I might weld some reinforcement ridges on them as well. My Kubota tech tells me several users have had them get bent so they destroyed the rubber boots. Seems like a weak point.
Did I mention that I routinely brush hog stuff over 2 inches in diameter? For safety sake I back into the big stuff. I do some stuff up to about 3 1/2 inches but for that I raise the brush hog way up and lower it down on the target, eating it as the implement lowers.
Again, thanks for the comments, guys. I will be looking at how to mount some skid plates/armor. I want to make it bolt on in a way that doesn't expopse the bolts to much destructive action (easier to R&R to do maint if required.)
Patrick
I have used perf metal for security screens before. The stuff I used wouldn't begin to pass a BB. The holes were just big enough to stick a round toothpick in about a quarter inch. Doesn't it cut down cooling airflow to the radiator?
I was thinking of two thicknesses of expanded metal running at right angles to one another.
   / Attacked by a branch #10
Have had no air flow problems. My bumper guard actually helped the situation. Before i was stopping every 20 minutes to clean the pre-filter, after, I got 30+- minutes. The bumper guard is about 3" forward of the hood, and is measured out so that the hood will just clear it when open.
Soundguy
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
6 pallets Miscellaneous PPE equipment (A53117)
6 pallets...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
