Attachment to pull a drag or pull trailer
   / Attachment to pull a drag or pull trailer #1
Florida
Allmand TLB 325
Has anyone built an attachment for their backhoe to pull a drag/cultivator or trailer. I know you can weld a receiver to the top of your loader bucket to position a trailer, but I would like to be able to toe behind my backhoe.
   / Attachment to pull a drag or pull trailer #2
Towing is not recommended using the backhoe bucket, but if you want to do it, Perhaps you could weld an attachment to the boom so it will clear the bucket when folded. This would be right close to the swing cylinders but in back of the boom. That would be the strongest point and would be pulling from the boom swivel pin and frame, NOT much chance of warping the boom or dipper stick that way. It should end up being about the same height as a regular tractor drawbar by doing it that way.
You would likely have to be careful when folding up the boom and bucket as it might hook it if you brought everything up prior to folding the bucket.
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
(3) VACUUM PUMP TANKS (A50854)
(3) VACUUM PUMP...
KUBOTA 1140CPX RTV (A51406)
KUBOTA 1140CPX RTV...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A49346)
2025 Kivel 42in...
