attachment to install water line?
/ attachment to install water line? #1
twodogs
Pittsburgh, PA
Kubota B7800
I have a Kubota B7800 & I would like to intall a shallow water line to my orchard. I am looking for an attachment & I was thinking of a subsoiler. I thought that if I use the subsoiler I would be able to place the water line in the in trench that it creates. I know that the line would not be below my frost line, but I plan on blowing it out with compressed air each fall.
Any thoughts or suggestions?
/ attachment to install water line? #2
I have had success with my subsoiler and PVC pipe on short distances (up to 100') . I welded a swivel on the subsoiler behind the point added a chain. I used a chain small enough that a link would go in the pipe. After I drilled a hole through the walls of the pipe I slipped a bolt in and through the chain link added some tape to keep the pipe from filling with dirt and pulled it in.
I am sure others can com up with better ways to attach the pipe to the chain but this will work on a budget.
If you wanted to use black poly pipe on a roll I am sure you could pull longer lengths I am not sure how many glued joints you can use in regular PVC.
good luck
/ attachment to install water line? #3
Saw a buddy's dad bury 400' of 3/4" PVC with a subsoiler when we were teenagers. He had a hole dug at the end of his run and thats where he pulled it to. The end was taped and chained to the subsoiler. I'm not sure how he secured the chain. That was a long time ago and we were usually drunk or hungover back then. Wish I'd paid attention.
/ attachment to install water line? #4
There are quite a few posts on this site about pulling PVC thru the ground using a subsoiler, some several hundred feet at a time(try the search function). If you don't pull it thru, you will still have to shovel. Subsoilers are great at ripping a trench, but not so great at getting the loose dirt up and out of the trench. I had to lay 400' of 2" and didn't think I could pull that large without fabbing a larger subsoiler head. I made a few rip passes to cut roots and rip rocks then used a narrow trench shovel(looks like a hand trowel on a shovel handle) to remove the loose soil to lay the pipe in the bottom. That was a lot of bent over work digging out the bottom of the trench. If you are going to pull, I would reccomend making a pass with just the subsoiler first to cut any roots or find any large rocks along the way then dig a start and end hole to pull the pipe from-to. It is pretty easy to drag the subsoiler along the same path repeatedly since the soil is already broke up. Once you start to pull the pipe, you really can't lift the subsoiler or back up to clear an obstruction.
/ attachment to install water line? #5
The cable co just installed a buried line to my house last fall. For free. What a deal. They pulled 400 ft of maybe a little over 1" orange chase. I asked them how they got the cable in it ,they said its already in it. They used a vibrating mole, sort of like the subsoiler you are talking about but it vibrated and it only made a slot about 1 " wide on the surface. They went about 18 inches deep and raised up a bit near trees. Rolled back over it with the tractor when they were done and you could not tell they were ever there. ok Have to work on thumbnails for pic files too big.
/ attachment to install water line? #7
When I drilled a new well last summer I rented a trencher for a couple of hours, maybe $40-$50. Got me down 2 1/2 to 3 feet for a 200 foot run. Quicker, easier and deeper then trying to use a ripper/trencher.
/ attachment to install water line? #8
I have a suggestion for winterizing it when you get it in. I have a campsite with thousands of feet of black poly laying on the ground. I blow it out at the end of each line, then use a utility pump and bucket to pump a few gallons of rv antifreeze in it, then hit it with the air again to blow it through the lines. Just blowing it out with an air compressor let water settle back it the low spots.
/ attachment to install water line? #9
carrickfad said:
That was a very informative thread.
Does anyone with experience have any comments regarding the differences between laying the pipe as in this thread and pulling the pipe through the ground?
It seems that laying with the elbow as in the linked thread would be gentler to the pipe than pulling the entire run through the ground. I know irrigation guys pull black poly all the time, but I am dealing with some really rocky ground.
Thanks for all of the suggestions! Great tips & advice from all!
/ attachment to install water line? #11
I just made up an attachment for my KK sub soiler on Saturday and plowed in 200 ft of 1 inch poly with my 2210 about 8 inches deep. I used a piece of pre bent electrical conduit to feed the pipe down in behind the sub soiler. I attached some tabs to the sub soiler and the conduit and then ran a rod through so the conduit could pivot like a rudder. It hangs back quite a ways and after seeing a post with a commercially available attachment that worked that way I thought it was a good idea. It was. I had to make about six passes without the attachment to soften the ground up and then I pulled the pipe in. It went in like closing up a zip lock bag. It was slick as anything. Where I had to go through sod I pre slit it with a shovel so it wouldn't tear it up as bad. I will probably make some changes to the attachment as it was all scabbed together out of what ever scrap I had but the basic prototype worked very well. I'll post some pics when I get a chance.
3pt Hitch Receiver  (A62679)
3pt Hitch Receiver...
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
New Holland TC29 Farm Tractor (A65579)
New Holland TC29...
Cub Cadet ZTR Zero Turn Mower (A66408)
Cub Cadet ZTR Zero...
2016 TAKEUCHI TB240 EXCAVATOR (A65053)
2016 TAKEUCHI...
New 2x27 Ratchet...
