attaching something to the 3 point
   / attaching something to the 3 point #1
ironman1952
2023 Kioti RX7320pccb
So I have the Kioti RX7320 that has the outside 3 point control lever. It is probably operator error. I thought this control lever works like the loader controller in that you raise or lower and when you let go of the lever it stops whether going up or down. This lever seems to let you go all the way up or all the way down, with no stopping intermittently.
Am I doing something wrong here? ugh :cool:
   / attaching something to the 3 point #3
Is the outside lever an inching lever and not a position control lever like the inside lever probably is? (most new tractors have position control levers).
An inching lever works like a rear remote without detents or float.
   / attaching something to the 3 point #4
I thought this control lever works like the loader controller in that you raise or lower and when you let go of the lever it stops whether going up or down. :cool:
I am not familiar with your kioti, but many rear 3pt's with levers instead of buttons are directly tied to the position control lever in the cab. Try moving the lever just a wee little and the hitch should move a little. Moving the lever all up or all down will make the 3pt do the same. Treat it like the lever in the cab and wee what happens.
   / attaching something to the 3 point #5
My dk45 has a lever that i can move to whatever level i want. Not just top and bottom. Not sure why yours is diffrent
   / attaching something to the 3 point #6
My Kubota L2501, has a knob below the seat that can be turned either way, to adjust how fast/slow the 3 point will raise/drop. Maybe your tractor has something like that?
2015 Ford F-350 Service Truck with Liftgate (A48081)
2015 Ford F-350...
UNUSED 2-Pack Yellow Outdoor Patio Fabric Screen (A50860)
UNUSED 2-Pack...
2017 Dodge Ram 4500 4x4 Crew Cab Reading Service Truck (A48081)
2017 Dodge Ram...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
Deere 9965 Cotton Picker (A50397)
Deere 9965 Cotton...
2012 Ford F-350 4WD Pickup Truck (A50860)
2012 Ford F-350...
