mkersey000
- Joined
- Jun 25, 2011
- Messages
- 8
- Tractor
- kubota bx2360
Bx2360.cannot get arms to lower to attach mmm.does the three point hitch need to be removed for them to operate?this is my first try at this.
You do not need to remove the 3pt setup.. A couple things to look at. First make sure the height adj knob for the mower deck is at 0.0. Next open up the lowering rate valve (just to the right of the height adj knob). Then if they still won't go down on their own, push down on the rear 3pt arms because sometimes it just takes a little weight to move them.. Note: the 3pt and the mower arms are connected to the same lift mechanism, but the mower arms can be held up by the height adj knob..
Did you set the mowing height adjust knob to zero? It holds the MMM linkage up. Youll probably have to raise the 3pt to be able to turn the knob easily.tried it. the 3-point hitch with rear blade attached goes up and down fine,but the arms for the mmm don't move.when i had the mower deck off i put a small protector shield over the hydraulic cooler fan . but it didn't seem to interfere with the mower deck arms.
